Can one use ffdshow as a decoder when watching through a capture card in virtualdub? Not capturing just preview/watching? If so, how does one do that?
Results 1 to 10 of 10
Probably not - application must provide "tee filter" or preview functionality - this is low level functionality provided usually or trough capture driver or additional system filter like mentioned "tee".
Do you specifically need to use VirtualDub? If not, you could use GraphEdit or GraphStudio to capture, pipe through ffdshow, then render to the screen.
Yes I would like to use virtualdub, I'm surprised but I can't find any info on this.
You can build a capture graph with GraphEdit or GraphStudio then open that as if it was an AVI file and "play" it with VirtualDub.
VirtualDub lets you apply filters while capturing (Video -> Filter Chain) and there's an ffdshow filter available for it (ffvdub.vdf). But the preview window always shows the video before filters are applied.
I figured out the problem, I was using virtualdub 64 bit while running ffdshow 32 bit. So I used virtualdub 32 bit with ffdshow and now ffdshow can do the video decoding when in capture avi mode!
decoder .avi YUY2 codec VFW that is not FFDshow
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2016, 15:09 -
Can't capture signal from JVC HR-S9911U VHS deck into Hauppage capture card
By vhscapture in forum Capturing and VCRReplies: 3Last Post: 18th Jul 2016, 13:07 -
Camera ffdshow/mjpeg capture colors are all wrong (possible yuv/rgb issue)
By alienvenom in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2016, 09:06 -
Is the Canopus ADVC-50 card still an OK capture card?
By Mickey Juice in forum Capturing and VCRReplies: 8Last Post: 21st Feb 2016, 09:34 -
is there a VFW decoder for mpg2 FOURCC ? (not ffdshow)
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 14th Dec 2014, 12:47
