I've checked the other threads about the AverMedia C027 and no one else seems to be having the same problem I'm having, so here it goes. I installed the drivers and AVer MediaCenter version that can on the disc from 2010, and the program wouldn't lunch, I tried it in every different compatibility mode, and it still wouldn't lunch. Then I uninstalled the program and drivers, and installed the newest version from the AVer site, and it still won't lunch. I tried using the card in VirtualDub, but it says that it can't connect to the drivers. Today I fingered out how to lunch Aver MediaCenter but it will only lunch when the drivers for my C027 are not installed; which doesn't do me much good. What I'm I missing? How can I get the drivers to be installed, and have the MediaCenter lunch at the same time. I'm running Windows 10 64bit on my machine. I would greatly appreciate any help with my problem.
Did you ever find a solution?
I just was forced to format my OS drive and re-load Windows 10 Pro 64... I used the C027 back in the fall just fine. Now when I tried to load the driver / software package I downloaded from http://storage.avermedia.com/web_release_www/C027/C027_AVerMCS_1.7.9.97.17090701_Drv_1..._Installer.exe I have a problem.
1. If I try to load the entire package, the OS locks up and is not repairable. I must re-install Windows by some means.
2. If I only install the software without the drivers, the software runs but can't find the drivers.
So it appears Microsoft has done something in the latest build that has a conflict with the drivers package. I wish I knew what it was or I wish I could find a usable driver set! This card was awesome to use and I hate to toss it over some MS BS. -
Have you tried running the driver installer in compatibility mode ?
As Win 10 "evolves" this kind of problem will increase. Probably best to buy a used XP PC and
just have it work -
Sorry for the forever slow reply back. I pulled the video capture card and bought a USB style capture device. It's not the greatest... I wish I could somehow get the AV C027 to work with Win 10
Need Original Drivers for Avermedia AverTV HD DVR (c027)
By Cam94Z28 in forum Capturing and VCRReplies: 189Last Post: 30th May 2023, 19:42 -
AVerMedia C027 Windows 10 driver is Setup_x64 or Win81_x64? [solved?]
By JefffKang in forum Capturing and VCRReplies: 2Last Post: 26th May 2016, 02:51 -
Avermedia C027 no audio through Denon receiver in Win7 64
By Bookemdano99 in forum Capturing and VCRReplies: 0Last Post: 9th Nov 2015, 15:59 -
Jitter on Avermedia C027 captures
By Caple in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2015, 13:17 -
having problems with avermedia h727
By cooldude101 in forum Capturing and VCRReplies: 2Last Post: 3rd Aug 2014, 09:52
