Some years back, Tsunami / Pegasys had a product called Tsunami MPEG DVD Easy Pack Suite.
One part of this suite was Tsunami MPEG Media Editor Easy Edition, which enabled one to extract and import mpeg files from a recorded DVD, and to render them as an mpeg file.
Is this capability included in TMPGEnc Authoring Works 6 (v6.0.9.11)?
I have scoured the menus, and I don't see this capability. Perhaps I'm seeing it, but not recognizing it because the nomenclature is unfamiliar to me.
If not, how might one otherwise render a DVD folder of a scene into an mpeg file?
Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
And MPEG2Cut2.
However, if using any of them you'll get back interlaced 29.97fps. If the VOBs are soft-telecined it'll be in your best interests to first strip out the telecine using DGPulldown (after demuxing). That way you'll get back progressive 23.976fps, rather than interlaced 29.97fps. And once demuxed, you use ImagoMPEG-Muxer to get the MPG.
How to render video to smaller file size and less quality for uploading
By BaseJump Improv in forum Newbie / General discussionsReplies: 4Last Post: 18th Aug 2018, 00:21 -
batch to get last modified file in a folder?
By marcorocchini in forum Newbie / General discussionsReplies: 4Last Post: 10th Sep 2017, 15:35 -
Preparing 720p File for Tmpgenc Authoring Works 5 (Smart Render)
By LIBERT4D in forum Video ConversionReplies: 41Last Post: 15th Jul 2014, 12:09 -
Cannot Render The File - Help
By majesty95 in forum Video ConversionReplies: 3Last Post: 11th Jul 2014, 22:49 -
no render information in video file
By moinsen1974 in forum Newbie / General discussionsReplies: 11Last Post: 29th May 2014, 01:57
