SLOVED - IN MEMORY MODE
My DCR-TRV520 doesn't have the MANUAL/AUTO STHR function after I disabled it. I reset the camcorder but the function is still gone.
do you have the instruction booklet that came with your camcorder ??
if yes try looking there. -
https://www.sony.com/electronics/support/camcorders-tape-camcorders/dcr-trv520
https://www.sony.com/electronics/support/res/manuals/W000/W0003098M.pdf
Selecting the mode setting of each item
Menu items differ according to the position of the POWER switch.
The LCD screen and the viewfinder shows only the items you can operate at the
moment.
AUTO SHTR
ON Meaning To automatically activate the electronic shutter
when shooting in bright conditions
OFF To not automatically activate the electronic
shutter even when shooting in bright conditions
Have you chosen the correct mode?
Best Sony Digital8 Camera to convert 8mm/Hi8 to PC?
By Optical in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 13th Feb 2026, 02:39 -
All the tricks transferring Hi8 to PC through Digital8 camcorders
By MtnFrost in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 23Last Post: 17th Aug 2018, 12:45 -
Digital8 camcorder not playing analog recordings well.
By digicube in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 11th Jan 2017, 18:10 -
How do convert a Digital8 AVI to play on a Roku3?
By Taney2 in forum Newbie / General discussionsReplies: 54Last Post: 1st Mar 2015, 09:58 -
Video8 camcorder - can it use Digital8 tapes?
By slow in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 22nd Feb 2014, 03:51
