Hi yet again!
In a nutshell, the problem is that I would like to decimate every other frame, to make my video half the length (from 20 minute video to 10 minute video), without lowering the FPS. I tried to use the Virtual Dub 2 internal "Decimate 2" setting, but the video was 20 minutes long after processing, almost as if it either did not decimate every other frame, or it created a copy of every other frame for every decimated one.
1. What Avisynth+ settings/plugins or internal VirtualDub2 tools could I use to cut the video length in half by decimating frames?
2. How to ensure that the resulting video remains 60 FPS after the decimate process? (Important for future purposes, if I need to cut and glue timelapse videos together with normal speed video)
Thank you![]()
In VirtualDub select Video -> Frame Rate. At the top select "Change frame rate to (fps): 120. Then in the middle select Process every other frame (decimate by 2). In general, change the frame rate to N times the source video's frame rate, and decimate by N. So to 240 and 4, for example.
An AviSynth:
Code:N = 2 # or whatever decimation value you want AssumeFPS(framerate*N) ChangeFPS(framerate/N)
Virtual dub does not display my video
By Hodar in forum Newbie / General discussionsReplies: 10Last Post: 26th Aug 2018, 03:55 -
Where's the video in Virtual Dub? I'm only hearing the audio.
By Vahan in forum EditingReplies: 4Last Post: 9th Mar 2018, 12:46 -
video into Virtual Dub
By lovebug in forum Newbie / General discussionsReplies: 2Last Post: 2nd Oct 2017, 06:25 -
Please explain me how to make my HD video properly ready for tv broadcastin
By Lav851 in forum Newbie / General discussionsReplies: 14Last Post: 10th Oct 2014, 23:30 -
Virtual dub-deleting frames
By Mr_Flintstone in forum EditingReplies: 4Last Post: 7th May 2014, 10:15
