Hello. I'm having problems at trying to record the stream in this asian site called pooq.
The channel which I intend to record is in the link from below:
http://www.pooq.co.kr/player/live.html?channelid=C2301
So far I tried to sniff the site using ublock which rendered the m3u8 as listed here but with errors
but when I try to use streamlink it gets me error that is 404 forbidden. I've also tried to use tubedigger however tubedigger was also unable to catch or record the stream digitally because it entered in a loop generating blank files and none shown any progress, in other words stuck at 0.Code:https://live-c2301.cdn.pooq.co.kr/hls/C2301/1/1000/live.m3u8
Does anybody can help me how to record from that site?. I really need this urgently.
Note. It may require the use of korean proxy. This latter part I was able to make it work, by using korea vpn you can watch the stream but cannot record, hence I don't know what other tool I can use. Can somebody enlighten me to this?.
	You're getting forbidden because it's geo blocked. You'll need to use South Korean VPN to download it with streamlink, ffmpeg, or youtube-dl.
 Using proxy will not work (tried it,still geo-blocked)
	Cookies and referer required, server response without 'CloudFront-Key-Pair-Id=', etc: Missing Key-Pair-Id query parameter or cookie value Last edited by TubeDigger; 24th Jan 2019 at 08:02.
	I did that and it still didn't work TubeDigger is stuck in a loop of generating blank files!.
 I used Korean VPN and it works. Does this counts as proxy?. Anyways with the VPN you mentioned the video stream plays fine. But I'm unable to get it work.
 The only thing I obtained was the m3u8 but it renders forbidden error and from there I don't know what to do.
 So how am I supposed to obtain those parameters?. I also tried to obtain this but I don't know. Therefore I need urgently help!!
	Probably I should answer before with attached screenshot, please see how it works fine:
 UPD: When you start TubeDigger you may read several tips on welcome screen, one of them is:
 Download waiting for manual start is marked as 'Idle'
 Therefore if you see 'Idle' status - it means several resolutions of stream were detected and you need manually to start stream of required resolution via double-click or right-click and selecting 'Start...' from popup menu.Last edited by TubeDigger; 24th Jan 2019 at 12:07.
  Download Streaming Site SubtitleBy bentheguitarman in forum SubtitleReplies: 4Last Post: 10th Mar 2019, 12:01
  Extract 'CC' subtitle from streaming siteBy quzma in forum SubtitleReplies: 4Last Post: 16th Sep 2017, 03:59
  foreign streaming siteBy bora in forum Video Streaming DownloadingReplies: 1Last Post: 15th Oct 2015, 10:57
  Re:Video Streaming in mvc siteBy premkumar in forum Video Streaming DownloadingReplies: 2Last Post: 17th Oct 2014, 05:43
  extraxt subtitles from streaming siteBy nedz9 in forum SubtitleReplies: 6Last Post: 17th Apr 2014, 08:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
