  1. I've got a CD-I disc that's only compatible with Philips CD-I players, that's full of video clips. I tried putting it in my DVD player (which plays VCD and SVCD) and it couldn't read it. I just put it in my CD-Rom drive, and when I open the CD-Rom, it says that the disc is empty.
    Is there any software I can download to rip this video footage from the disc, and let me convert it to MPG?
    -Mark
    Jan 2002
    Houston, Texas.....originally the UK
    Take a look at:
    http://www.icdia.org
    They have software for your PC that enables you to read the CDi disks on your PC and extract the MPEG's etc.
  3. thanks a lot!
    any ideas which program I'd need?
    Jan 2002
    Try the CD-i Filesystem Driver 2.0 (Beta) for Windows 95/98/Me
    I dunno if it works with XP. You'll be able to treat your CDi disks like regular VCD's with this software (assuming your CDROM / DVD drive is CDi file system compatible which most are)
    Alternatively ISO buster will achieve the same function, but in a less straight forward manner.
    Have a look at the PC/Windows download section and the CDi disk tools section for me details.
    Good luck
  5. i got it working with ISOBuster. just opened the CD up in that program, extracted the rtf files to my computer, and I'm now converting them to VCD standard MPG's. thanks
    -Mark
