Hello.
I've just bought a LG smart tv and I was trying to see a movie (.mkv) plugging a HDD on tv.
I can see it properly and I can also choose the language, but I can't set any subtitles (the icon is disable).
I've read I should take subtitles out of the mkv file, but I prefer not to change the file, cause it can be I'm watching that also on pc.
Is there a way (like downloading another program for watching movies) for being able of choosing subtitles?
Thanks.
Luigi.
You won't be changing the file. You'll still have the embedded subs (which, apparently, your television can't read), but you'll also create an external subtitle file. You'll just be using the MKVExtract portion of MKVToolNix.I've read I should take subtitles out of the mkv file, but I prefer not to change the file,
Also make sure the subs are in a format your television supports. -
I tried an MKV with SRT subs on my LG smart TV played back from a USB thumb drive
and the subs work fine. This is the first time I ever tried this, I always use the local
network to playback from my Windows PC using the windows media server.
Perhaps hit the down arrow for the controls, scroll all the way to the right to the 3 dots (...)
and select that perhaps the subs will be available.
This is how the subs look in mediainfo:
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 2 h 42 min
Bit rate : 39 b/s
Count of elements : 1325
Stream size : 47.5 KiB (0%)
Title :
Language : English
Default : Yes
Forced : Yes
How to turn off subtitles on an MKV file?
By ryansclzo in forum SubtitleReplies: 10Last Post: 30th Nov 2024, 21:59 -
Hardcode subtitles into a MP4\MKV file
By uncivil002 in forum SubtitleReplies: 18Last Post: 12th May 2015, 05:16 -
Please help me burn in subtitles to MKV rip file of blu ray (mkv/handbrake)
By jimbanville in forum Blu-ray RippingReplies: 1Last Post: 23rd Jan 2015, 09:45 -
How to add subtitles to an MKV file
By jk7398 in forum SubtitleReplies: 1Last Post: 6th May 2014, 17:00 -
Editing subtitles in an mkv file
By okizen in forum SubtitleReplies: 4Last Post: 26th Feb 2014, 21:35
