Page 3 of 3
FirstFirst 1 2 3
Results 61 to 66 of 66
  1. i have fund this with google search: https://github.com/streamlink/streamlink/issues/2148
    anyway i don't understand because all these problems when, if i run the normal win cmd and paste the string, everything works fine...
    mine was just a curiosity, but perhaps it is better and easier to use the classic win cmd....
  2. I have no decent words.
  3. You can download almost everything
    @ LZAA
    Hi. Can you point such kind of sites that are impossible to download contents? Does it legal to mention such sites ( names / links ) here, as example?
    Thanks.
    Best regards.
    devil (johner)
  4. Some can download from everywhere, but not all.
    You can send PM.
  5. Hi Iomero ,
    echo -----------------------------------------------
    echo     Quel TYPE de 'Plugin' ?
    echo.
    echo    httpstream	... 1)
    echo    hlsvariant	... 2)
    echo    hls		... 3)
    echo    hds	        ... 4)
    echo    akamaihd	... 5)
    echo    aucun	        ... 6)
    => for example you could write :
    streamlink ... "httpstream://http..."
    Cheers .
    JE SUIS CHARLIE !!!
  6. tanxs aazerty for your reply, but not work for me...
    i have try:
    streamlink --http-header Origin=https://www1.javbuz.com "httpstream://https://xiao.smamuhh1metro.com/7UA17cpR72TgedjW6eL3EzjTD8vxNBFUotxY7Sey7aC1LSsK7I/0/VzWnW81hXzBaW8JDBrkSKPFuKRBkYqvPYgjiB5vstRmwC8FCJLjx15vEXzs/717401c0802e4064d30aa856a8245ee5.m3u8" best -o video.ts
    select this code, opens stremlink.exe, write "paste" in black windows, but i have always same error: "No plugin can handle URL: paste"
    anyway, repeat, work correctly with win cmd, paste string and streamlink work correctly!
