Hello everyone,
I'm totally new here, like I'm new in transferring VHS to digital. Will try to make it short. I'm not a professional or something and this was my first attempt to transfer VHS to PC. At first I thought - no problem, I'll just plug in VHS to PC (it has a TV card) and basically everything did worked - there was sound, there was image and I thought that's it. But When I did transferred VHS to PC I found some problems with the image: it seems that whenever VHS camera were shacked a little bit more while filming - it has jumping/jitter problem in my new transferred to PC VHS rip.
Here's how it looks:
While watching the tape on the TV (the cables are the same) it doesn't have such issues. I've tried to do some different configurations, different softwares, but the problem is still the same, so I guess it's not the software or anything else, but probably a hardware.
Anyway, could somebody explain for a newbie why this is happening and how this can be fixed?
Results 1 to 9 of 9
Do you have a video clip of this? Still shots aren't much help when discussing video problems.
And welcome to our forums. -
sorry, here's the short video clip:
https://forum.videohelp.com/images/imgfiles/TAs7tYf
as you see at first everything's fine, but when the camera starts shacking it has this annoying jumping. on TV everything is OK, without these side effects.
the other scenes where the camera smoothly moves/zooms also doesn't have that jumping image, it seems that this kind of "jumping" starts whenever the camera was shacked a little bit more -
This is a synchronization problem. TVs are much more forgiving of timing variation than are digital converters. If your VCR has a TBC or stabilizer function, turn it on. Otherwise, you will need a frame synchronizer in between the VCR and the PC.
Thanks JVRaines! so getting the frame synchronizer is the only possible way to fix such issues?
Yes. The problem is in the analog domain. There's nothing to do about it in software.
thanks, will need to learn more about this.
what about the vhs/dvd recorders (where you can record from vhs to dvd or hdd - JVC DRMV5S for example)? anyone here have tried them? do these recorders eliminate such problems as in my video rip? -
The Panasonic ES-10 and 15 have built-in timing correction which handles many of these problems. Other models do as well. They are often used as passthrough signal conditioners without going to DVD.
Lack of TBC is the issue.
VHS jitters with TBC turned on
By timmus in forum RestorationReplies: 10Last Post: 19th Aug 2015, 11:37 -
A tad bit a help please. Capture from VHS camcorder Panasonic Omnimovie HQ
By anbu_zim in forum Capturing and VCRReplies: 11Last Post: 31st Mar 2015, 18:55 -
VHS transfered to DVD, sound has hisss
By rockonvidtrade1 in forum RestorationReplies: 33Last Post: 25th Mar 2015, 16:22 -
Can anyone help identify which '80s VHS camera was used to film this?
By alexjoy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 8th Mar 2015, 16:24 -
Please help me fix my solid state VHS camera
By 4yfanatic20 in forum Newbie / General discussionsReplies: 7Last Post: 1st Jul 2014, 19:35
