you don't. it's a lossless yuv codec. no choices there.
Yes; for all lossless codecs . They allocate whatever is required to satisfy the "lossless" condition
You have some minor control over some of them in terms of compression ; for example, a longer GOP size will typically improve compression efficiency. Ballpark estimate for long GOP lossless vs. I-frame lossless would be ~25-50% bitrate reduction. But you will never be able to achieve a CBR profile (unless you add something like padding or stuffing)
transcode Variable Frame Rate (VFR) AVC video to Constant Frame rate (CFR)
By hydra3333 in forum Video ConversionReplies: 2Last Post: 4th Mar 2018, 05:01 -
Good Bit rate for HD Video
By jozamm in forum Newbie / General discussionsReplies: 2Last Post: 9th Jun 2017, 16:25 -
How does bit rate effect video and slide quality?
By johnharlin in forum Video ConversionReplies: 1Last Post: 31st Dec 2015, 19:29 -
Bit Depth,Sampling Rate used for Uncompressed Audio-Bit Rate for Compressed
By alexander121 in forum AudioReplies: 9Last Post: 4th Apr 2015, 10:30 -
Video conversion bit rate mismatch??
By socrates in forum Video ConversionReplies: 4Last Post: 6th Jul 2014, 08:54
