Dear ALL,
I need to upload srt (vtt) files to VIMEO for a multiple language choice for the audience on VIMEO before releasing a short film.
I need to:
Change fonts (size and style) and avoid if possible the ugly black squared background of the standard srt files, How could I do easily to obtain a VTT files already ready for VIMEO?
NOTE that I don't need to change for my own pleasure but to assure a better style of them for the VIMEO release...Thank you!!
I have the srt as well so if VTT are not manageable I could import the srt after have changed them but seems that with VTT is better.![]()
Those are called 'styles' and SRT and VTT have none of that. The styles are set by the player, so any styles settings are done in Vimeo. Maybe they can be adjusted by the viewer. I don't know as I don't use it myself. There are two text-based subtitle formats in which you can adjust the styles to your liking (ASS and SSA), but YouTube won't accept them and I don't guess Vimeo does, either.
I came across this which has styling including color changes: https://www.w3.org/TR/webvtt1/. Implementation in Vimeo is my next step. So far, it's not recognizing any styles from examples in those specifications, but I've hope some combination will work.
change subtitle style for multipe subtitles files
By simonrule in forum SubtitleReplies: 8Last Post: 21st Jul 2018, 13:41 -
Change Fonts in Subtitles and Title in mkv File
By RBCC in forum SubtitleReplies: 26Last Post: 19th Apr 2017, 13:25 -
how to put background or solid block of color on a video
By damesquad73 in forum EditingReplies: 1Last Post: 2nd Apr 2017, 18:34 -
MediaPlayer Classic Home Cinema -> Change window background color?
By jgg in forum Software PlayingReplies: 7Last Post: 17th Aug 2014, 04:24 -
background color
By JoeSinger in forum Newbie / General discussionsReplies: 11Last Post: 25th Feb 2014, 08:21
