I have just started using VSDC video editor. When playing the source video on my laptop the content is smooth but if I import it into the editor and play the same file back, it stutters. Any suggestions gratefully received.
Many thanks.
Different decoding pathway . Media players are often GPU accelerated
VSDC is probably CPU decoding, and it's not fast enough for realtime playback, so it's dropping frames. If you step through frame by frame, the frames are probably there, it' s just skipping them because your hardware isn't fast enough, and the editor isn't optimized enough.
You can try reducing the playback resolution or using proxy editing. I doubt VSDC has an established proxy workflow , but it involves making lower quality/lower resolution versions for faster editing performance , then you swap back to the high quality originals on final render . -
Thank you for the reply.
I will take a look at the playback resolution as it seems the simplest method for a novice like me!
Cheers
can't fix choppy/stuttering Video Playback
By Gwar in forum Software PlayingReplies: 11Last Post: 8th Feb 2019, 18:47 -
How to restore Audio to preview playback in VSDC Editor ? Please help.
By rcronebach in forum AudioReplies: 0Last Post: 11th Aug 2017, 15:41 -
Stuttering in the edited video
By djavh in forum EditingReplies: 7Last Post: 24th Sep 2015, 16:22 -
causes of choppy / stuttering video
By cheyrn in forum EditingReplies: 15Last Post: 7th Dec 2014, 15:00 -
HD black screen and stuttering.
By AnonyMouse901 in forum Newbie / General discussionsReplies: 5Last Post: 20th Sep 2014, 20:45
