My authored Blu-ray video only 4 GB in size. If I burn it on a DVD, can a Blu-ray player play it?
A Blu-ray player that includes AVCHD support might play it if the bit rate isn't too high. (Max total bitrate for AVCHD on DVD is 18 Mbit/s) DVD5/9 media doesn't support using the higher bit rates that Blu-ray often uses. The transfer rates of DVD media are too low
AVCHD was invented to allow authoring HD video and burning to DVD media. Very old Blu-ray players may not support AVCHD, but many recent ones do.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
AVCHD is different from Blu-ray.
If the OP's file structure is really Blu-ray, many if not most players may spit the 4.7 GB disc out even though the bitrate and VBV parameters were set for DVD media. My old SONY BD player (now dead unfortunately) however used to play such discs. My newer Samsung Blu-Ray players accept Blu-ray file structures only when the video stream is fully Blu-ray compliant and burnt on a 25GB disc.Last edited by Sharc; 16th Jan 2019 at 02:20.
Leawo Blu-ray Player: Problems Playing Blu-Ray Discs
By devilcoelhodog in forum Software PlayingReplies: 11Last Post: 24th Mar 2017, 08:32 -
Blu Ray iso on a DVD...will it work on a Blu Ray player?
By DumdogsWorld in forum Newbie / General discussionsReplies: 5Last Post: 25th Nov 2016, 05:09 -
LG blu-ray player is stopping playing blu-ray discs
By mausinho in forum DVD & Blu-ray PlayersReplies: 2Last Post: 22nd Feb 2016, 09:55 -
Sony BDPS5500 Blu-ray Player VS Samsung BD-J5700 Blu-ray Player
By tarzan54 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Jan 2016, 20:51 -
Blu-ray player to play "X-Men: Days of Future Past" blu-ray
By nekros111 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 6th Sep 2015, 04:06
