I have a Managnox VCR/DVD player combo from 2009. It says it was manufactured in October 2009. Now since the analog to digital switch happened in June 2009, would this machine work with digital ATSC? Yes, I'm aware that VHS quality would suck and this isn't a DVD recorder, but would it?
If only there was a model number in your post someone might look up the the specs and provide you with the information you want. Alas there is none.
The manufacture date tells you nothing about the presence of an ATSC tuner. Magnavox made some VCR/DVD player combo units with no tuner after the 2009 DTV transition. The VCR would only record from its composite video and analog stereo audio connections.Ignore list: hello_hello, tried, TechLord, Snoopy329
Panasonic VCR/DVD combo player has sound but scrambled picture
By three4rd in forum DVD & Blu-ray RecordersReplies: 10Last Post: 22nd Apr 2017, 17:35 -
Capture options: VHS to digital using DVD/VCR combo (dvd-VR355) and GT 630
By ThreePeak in forum Capturing and VCRReplies: 1Last Post: 18th Jul 2016, 02:18 -
question, witch old dvd / vcrs have an ATSC digital tuner
By tigergriz in forum DVD & Blu-ray RecordersReplies: 3Last Post: 15th Feb 2016, 15:39 -
Help. Copy VHS to PC with TV card ViXS PureTV-U 48B0 (NTSC/ATSC Combo)
By Krazedav in forum Capturing and VCRReplies: 19Last Post: 28th Dec 2014, 14:22 -
Capturing VHS with VCR or Blu-ray/VCR combo?
By SyncroScales in forum Capturing and VCRReplies: 11Last Post: 26th Dec 2014, 09:39
