Results 1 to 26 of 26
  1. https://www.bbc.co.uk/iplayer/episode/m0001y8k/guitar-drum-and-bass-series-1-1-on-drum...ewart-copeland
    can anyone help me download this. windscribe, which sometimes works with iplayer, is on a not working phase. I think it is a three part i only want the first episide
  2. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    Streamlink can do it.
    streamlink --bbciplayer-username XXXXX --bbciplayer-password XXXX https://www.bbc.co.uk/iplayer/episode/m0001y8k/guitar-drum-and-bass-series-1-1-on-drums-stewart-copeland best -o output.ts
    Replace XXXX with your actual login credentials. If for some reason it downloads only SD streams you can add --bbciplayer-hd to the line.
  3. Thanks. I get "streamlink is not recognized as an internal or external command operable program or batch file"
  4. Open cmd in the Streamlink directory.
  5. Originally Posted by LZAA View Post
    Can you remind me how to do this?is it same as cd to the streamlink directory? And also i have the portable streamlink
    Will geolocate matter when i do that
  6. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    Navigate to Streamlink\Bin folder where streamlink.exe is located. While holding shift key,press right click and "Open command window here".
    Note that if your installation of streamlink is in Program Files/Program Files (x86),you will need to run CMD as admin in order to write a file.
  7. Originally Posted by Sviests View Post
    i did that but still get the error "streamlink is not recognized as an internal or external command operable program or batch file"
  8. Originally Posted by LZAA View Post
    Reinstall Streamlink.
    I have the portable. i re uncompressed it. i get
    C:\Users\username\PORTABLE\STREAMLINK\streamlink-portable-master\streaml
    ink-portable-master\Streamlink for Windows (Compiled)>streamlink --bbciplayer-us
    ername xxxxxxxxxxxxxxxx --bbciplayer-password yyyyyyyy https://www.bbc.co
    'streamlink' is not recognized as an internal or external command,
    operable program or batch file.
    where am i going wrong?
  9. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    It means you don't have a streamlink.exe in there. It's best if you install it via setup and not using portable version.
  10. Originally Posted by Sviests View Post
    OK there was a streamlink for windows.exe in there. I thought that was it
  11. i use portable and got the updated portable from LZAA's link. I get
    C:\Users\username\PORTABLE\STREAMLINK\Streamlink_f or_Windows_Portable_v0
    .14.2>streamlink --bbciplayer-username xxxxxxxxx --bbciplayer-pass
    word xxxxxxx https://www.bbc.co.uk/iplayer/episode/m0001y8k/guitar-drum-and-bas
    [Streamlink for Windows v0.14.2 - Git 215d789]
    [cli][info] Found matching plugin bbciplayer for URL https://www.bbc.co.uk/iplay
    [plugin.bbciplayer][info] A TV License is required to watch BBC iPlayer streams,
    see the BBC website for more information: https://www.bbc.co.uk/iplayer/help/tv
    licence
    File "C:\Users\usernames\PORTABLE\STREAMLINK\Streamlink _for_Windows_Por
    table_v0.14.2\Streamlink\streamlink\plugin\api\validate.py", line 482, in valida
    te
    return validate(self.schema, value)
    File "functools.py", line 803, in wrapper
    File "C:\Users\username\PORTABLE\STREAMLINK\Streamlink_ for_Windows_Por
    table_v0.14.2\Streamlink\streamlink\plugin\api\val idate.py", line 334, in valida
    te_all
    value = validate(schema, value)
    table_v0.14.2\Streamlink\streamlink\plugin\api\val idate.py", line 371, in valida
    te_dict
    raise ValueError("Key '{0}' not found in {1!r}".format(key, value))
    During handling of the above exception, another exception occurred:
    File "C:\Users\USERNAME\PORTABLE\STREAMLINK\Streamlink_ for_Windows_Por
    table_v0.14.2\Streamlink\streamlink_cli\main.py", line 533, in handle_url
    streams = fetch_streams(plugin)
    table_v0.14.2\Streamlink\streamlink_cli\main.py", line 413, in fetch_streams
    sorting_excludes=args.stream_sorting_excludes)
    table_v0.14.2\Streamlink\streamlink\plugin\plugin. py", line 431, in get_streams
    return self.streams(*args, **kwargs)
    table_v0.14.2\Streamlink\streamlink\plugin\plugin. py", line 339, in streams
    ostreams = list(ostreams)
    table_v0.14.2\Streamlink\streamlink\plugins\bbcipl ayer.py", line 234, in _get_st
    reams
    vpid = self.find_vpid(self.url)
    table_v0.14.2\Streamlink\streamlink\plugins\bbcipl ayer.py", line 139, in find_vp
    id
    vpid = m and parse_json(m.group(1), schema=self.mediator_schema)
    table_v0.14.2\Streamlink\streamlink\utils\__init__ .py", line 66, in parse_json
    json_data = schema.validate(json_data, name=name, exception=exception)
    table_v0.14.2\Streamlink\streamlink\plugin\api\val idate.py", line 484, in valida
    te
    raise exception("Unable to validate {0}: {1}".format(name, err))
    table_v0.14.2\Streamlink\Streamlink.py", line 10, in <module>
    main()
    table_v0.14.2\Streamlink\streamlink_cli\main.py", line 1002, in main
    handle_url()
    table_v0.14.2\Streamlink\streamlink_cli\main.py", line 537, in handle_url
    I eventually got it with youtube dl and windscribe on a windscribe 'good day' But i would like to learn where i go wrong with streamlink. Thanks for the help guys
  12. Check the authorization on the site with this data.
  13. Originally Posted by LZAA View Post
    Do not understand sorry
  14. Can you login to this site?
  15. Originally Posted by LZAA View Post
    into bbc? yes i can. But i still get the error when I try to stream
  16. In order to figure this out, I need access.
  17. Originally Posted by LZAA View Post
    to what? I cannot give my username/password to bbc iplayer
  18. Member
    Nov 2014
    Germany
    Download Link for the video :
    https://bbcfmt-ic-1f03fe00-0b4a45-vodhlsuklive.s.loris.llnwd.net/usp/auth/vod/piff_abr...o=5070000.m3u8
    You can download with several programs:Youtube -dl,Streamlink,Livestreamer or FFmpeg
    I prefer to extract the m3u8 in a txt.file and downloaded the similar .ts files
    Hope that helps!
    You can start the download without username and password
  19. Originally Posted by ghostrewel View Post
    Hope that helps!
    Thanks. I got it with youtube dl which works when windscribe works fr bbc- sometimes. Are you using a vpn? Streamlink does not work for me
    Nov 2014
    Germany
    Command for streamlink
    streamlink hlsvariant://link best -o name.ts
  21. Originally Posted by ghostrewel View Post
    I get
    error: Failed to parse playlist: Missing #EXTM3U header
    [End of Streamlink for Windows with ExitCode 1]
  22. streamlink hls://link best -o name.ts
  23. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    I get
    It's a streamlink issue now. It happens with DRM content. If youtube-dl worked fine,great. At least one tool was able to get it done,that's all that matter,i guess.
  24. Member
    Nov 2014
    Germany
    A simple way to find out the best available quality is to update to the newest version of Youtube-dl
    Command youtube -dl -F link
    copy the highest part amd put them into following
    youtube-dl -f quality link link of the video
