I have recently got a DVD rip in 2 SVCD ready MPEG files. Normally I always use VCDImagerGUI to convert the MPEG to bin/cue and burn with Fireburner which I have found is the easiest way (for me anyway).
I have never had any probelm this way until now. In VCDImagerGUI after scanning the MPEG file it gives me this messege:
INFO: scanning mpeg track #0 for scanpoints...**ERROR: scanning error 0x00000000 2324
I have also tried to burn in NERO which I am not too familiar with and I get errors before burning.
I have checked the files and I am certain they are SVCD ready files and can't understand why I can't make a CD.
I would be most grateful for any help or suggestions on any other software which may allow me to make an SVCD from these files. Thankyou very much.
Have you done the same exact thing before?
It sounds like you have shitty software or have a computer virus.
The Terapin VCD Recorder
www.VCD-TRADING.com
Check it out and Start Trading Today! -
Thanks for your reply but I have used this software sucessfully before and I know I have definitly not got a virus.
It sounds like you've got some packet anomoly in the MPEG video files. I experienced a similar problem with a set of files I had edited with another program.
Remux the files in TMPGEnc and try again. -
Thanks for your help Dave B but how do I do that.
I know I sound a bit stupid but I am not too experienced with TMPGEnc. When I load my file into it, it says "cannot open or unsupported"
Don't know if I am doing this right though.
Thanks again. -
Read about how to remux it here
http://www.vcdhelp.com/faq.htm#repairmpg
You will want to set the "Type" box to MPEG-2 Super Video CD or similar (I can't remember what it is called exactly) The FAQ also gives you a few more options to try (e.g. MPEG_Corrector software) before you give up with frustration.
Good Luck
Unable to Use Batch mode in MPEG STREAMCLIP for DVD Convert
By winston879 in forum Video ConversionReplies: 0Last Post: 14th Mar 2011, 01:38 -
mpeg streamclip unable to mark in and out
By Robertom in forum DVD RippingReplies: 2Last Post: 9th Mar 2011, 14:06 -
By nimrodm in forum Video ConversionReplies: 0Last Post: 3rd Jan 2010, 08:27 -
Unable to play MPEG-4 files
By rama_m in forum Software PlayingReplies: 10Last Post: 22nd Aug 2009, 09:12 -
unable to open mpeg-2 video
By yic17 in forum Video ConversionReplies: 1Last Post: 27th Sep 2007, 14:41
