Hi forum, i was reading some post and i found the site very useful so thanks for that.
I am having a problem with my capture card since i upgrade to the latest firmware version so i am trying to go back to previous version and i can not.
I try different previous versions of the firmware and when i try to install them i get the message "You are using the latest version now" so i can not downgrade the firmware and with the latest one Free PC mode does not work. Any other way to hack it or downgrade the firmware or factory reset or something to make this work?
Thanks in advance
I did that already but when i try to install previous versions of the firmware i get the message "You are using the latest version now" so i can not downgrade the firmware or to anything at all.
Then you need a technician to manually program the older firmware with a proper equipment.
In Argentina must have a computer shop somewhere there that does PC repair, motherboards, VGA boards, etc. Just the programmer cost about $350 bucks, you need a pcb preheater, proper soldering and desoldering tools, power supply, oscilloscope, knowledge, etc, etc.
Look at DIY forums around the net, we don't do this here. -
Hello,
Can I check why you want to downgrade to an older firmware version for your C875?
Is it for the same reason as me?
I've been using my C875 for many years without problems, capturing 1080p video and since flashing the latest V27 firmware, I can only capture in 720p.
I need a way to downgrade for this reason, can anyone help?
Cheers,
Travis
[AVerMedia News] Avermedia RECentral HDCP Protect Remove!!!
By Cauptain in forum Capturing and VCRReplies: 234Last Post: 31st Dec 2025, 19:15 -
Avermedia C875
By rcase355 in forum Newbie / General discussionsReplies: 0Last Post: 24th Oct 2018, 15:48 -
Does MakeMKV downgrade Blu-ray Quality?
By Speeny in forum Blu-ray RippingReplies: 4Last Post: 28th Mar 2015, 03:03 -
What resolution should I downgrade to?
By ErikJon in forum Video ConversionReplies: 4Last Post: 26th Feb 2015, 19:13 -
Downgrade 1080p to 720p and change the aspect from 4:3 to 16:9
By Gerff in forum Newbie / General discussionsReplies: 8Last Post: 29th Sep 2014, 05:02
