Page 1 of 3
1 2 3 LastLast
Results 1 to 30 of 67
  1. Hello I do have a question. So, how can I get the m3u8 link, what user agent should I use, because I tried every android,iphone and windows phone and I keep getting the "dont open developer tools"
  2. Firefox browser + HttpFox add-on.
  3. Originally Posted by LZAA View Post
    Is there an equivalent of HttpFox for newer versions of FireFox?
  4. I do not know.
  5. Originally Posted by LZAA View Post
    I cant play the video with that old firefox, ive tried even with another browser that supports that httpsfox but its not playing the video too.
  6. Originally Posted by LZAA View Post
    Fiddler.
    Ive never used this software before, how can i get the m3u8 link?
    Edit: **** it. Now I cant even play the video on the chrome shit or any browser. Getting this error: Too long loading player, if you have adblock - disable it, and refresh page.
  7. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    Adblock prob the issue,i hate sites with too many adds however.
    Can you give us the link to embeded video please?
  8. Browsers: IE, Edge, Chrome.
    Fiddler:
    Tools -> Options -> HTTPS:
    a) Capture HTTPS CONNNECTs
    b) Decrypt HTTPS trafic
    c) Actions
  9. Originally Posted by LZAA View Post
    Fiddler:
    c) Actions
    Not working, i think i got banned because of that program.
    and the embemed is : "https://hqq.tv/player/embed_player.php?vid=cThHQm0vZUhGcmlaL2FaMCtwUEk1d z09&autoplay=no"
    but i want to download more episoades.
    heres the site : https://www.musteata.com/2017/09/sa-nceapa-aventura-dublat-in-romana-sezonul-5-episodul-1/
  10. What does "Does not work" mean?
    What have you done, and what is going on? In detail.
  11. Originally Posted by LZAA View Post
    When i start the app its all good, but i cant open the link. I mean i cant start the video on the site. I get ban and I have to wait some hours to get unabnned. So, after i open the app , i cant play the video, its loading forever and not starting
  12. How I have downloaded some m3u8 links onto Windows 7
    On your desktop/laptop
    Save the webpage as HTML.
    Find the link with M3U8 suffix.
    You can use cygwin:
    cat filename.html | grep -i "m3u8"
    Or, search in notepad
    Then, use:
    Video download capture from apowersoft.com
    https://www.apowersoft.com/video-download-capture.html
    With some websites, I could use cygwin:
    wget "the_HTTP_link.m3u8"
    Although, with some websites, both methods did not work
  13. Originally Posted by videonewbie22 View Post
    You can use cygwin:
    Then, use:
    tested, not working
  14. Firefox browser + HttpFox add-on.
    It works: checked.
  15. Originally Posted by LZAA View Post
    It works: checked.
    what firefox version are u using?
  16. Originally Posted by LZAA View Post
    Go top down.
    What do you mean?
  17. Originally Posted by LZAA View Post
    Go top down.
    Im sorry for 2xpost but I think ive tried every single version and its not working.
  18. Write in detail what and how you are doing, and what result you get.
  19. Originally Posted by LZAA View Post
    For some firefox versions https is not supported. I got some supported ones but I can't play the video. Its just not showing up, nothing, nada, just a blank space.
  20. Try TubeDigger
    What versions of Firefox does the HttpFox add-on work with?
    ESR 52.9.0 (26.06.2018) or Cyberfox 52.9.1
  21. What versions of Firefox does the HttpFox add-on work with?
  22. Originally Posted by sysanin View Post
    Try TubeDigger
    Thanks for the reply, now its working httpfox but i dont know how to download the video or atleast to get the m3u8.
    I've searched "m3u8" but i get nothing.
    I only get same link but i dont know what to do.
  23. Watch carefully.
  24. Originally Posted by LZAA View Post
    Watch carefully.
    Nevermind man. Thank you so much. I found the link.
    I had just to search "vkcache" and is a link named blbalba-m3u8
  25. Member
    Feb 2019
    Poland
    How did you manage to get a m3u8 link? Im also trying to manage to download a movie from netu.tv but only links which i get using httpfox is some 3MB parts of a movie as shown in the photo below
  26. sorry for this post... but i'm curious...
    @ madnesofjuice your link at post #10 (https://www.musteata.com/2017/09/sa-nceapa-aventura-dublat-in-romana-sezonul-5-episodul-1/) not work...
    please post new correct link.... i want try....
  27. Originally Posted by lomero View Post
    https://www.musteata.com/steven-universe-in-romana-sezonul-2-episodul-3/
    try here
    Give me the link, i will try to check, it should work.
    Find the application/octet-stream-m3u8
  28. Member
    Feb 2019
    Poland
    Thanks for your answer, here is a video which i would like to download:
    https://kinemania.tv/mutluluk-zamani-englishsubtitles/
    I found m3u8 link but i cannot download it using ffmpeg. It still gives me http error 403 as you can see on the pic below
