Hi All
I have a 1080p video, 2hrs long, 5.1 channel audio and is a 5GB size TS file. I want to convert it to 720p MP4 format and reduce its file size to about 900 mb - 1GB ( if possible). I don't mind the audio to be converted to stereo to reduce its size. I also want to edit / cut some scenes out of it ( adverts).
I have used Cyberlink Powerdirector 12, but video and audio get out of sinc and cant really find way to reduce its size using this program. Plus it takes over 2 hours to convert. - is this normal.
Are there any FAST converters out there that can help with the above.
Ive also used handbrake - but cannot cut scenes.. and HD Video converter ( wonderfox)- but this is taking nearly 3 hours.
Thanks for your help.
Results 1 to 15 of 15
You won't know, until you ask
Use Avidemux to cut the commercials; you can cut on i frames only (use the up and down arrow keys
in the program to navigate to them) but it may be accurate enough.
Leave video and audio as "copy" (on the left)
Save output format as mpeg TS muxer. Save the file and re-encode it in Handbrake or Vidcoder.
Use the very fast preset and set CRF between 20 - 22. This is a reasonable setting.
Encode and check the size -
Hi davexnet
Thanks for your reply. i shall give this a go.You won't know, until you ask -
mukeshs: What kind of processor do you have in your computer? I have an i5 and it would probably take me about a hour maybe less to encode that video. When you have edited the video before you attempt to shrink it down to 720p does it have any audio sync issues? I have found I have audio sync issues is I shrink video and pass through the original audio stream to combine with that new video. Also are you sure that the original video is not 1080i instead of 1080p; that could explain why it is taking 2 hours to process as it is converting to progressive from interlaced as I have found that takes more time to do. Perhaps you could try a trial version of videoredo to edit your video. I am glad you are using the CRF method as that makes a huge difference in video quality because it gives your action scenes the bitrate they need to look decent. If you had just set a target size I don't think you would have been pleased when it came to an action scene. I use Vidcoder which is based on Handbrake as I find it easier to understand. The terrific thing is once you have found the right settings you can save a preset but I am sure Handbrake allows you that as well. Maybe you should do a media info for the original file, the edited file before shrink and finally your 720p encode and it will be useful for people to give you some additional help.
Tom Saurus
Thank you for your detailed response. Very helpful. I am using a laptop i5 processor to do this work. Not sure if the video is 1080i or 1080p. I thought it was 1080p. Media info only states 1920 by 1080, so assumed it was full HD. Having trialed and error on Handbrake, I kept the Audio bit rate at 384kbps and video at 30 fps ( These figures were the same as the original) and this appears to have rectified the video and audio sync, albeit that that file size is 1.2GB and only took an hour to encode. Where as previously with the sync issue the file was 900 MB. 1.2 Gb is Ok for me. Quality is just as good. I shall try Vidcoder too. -
You can also try VOB2MPG. It will leave you with an MPG file that you can then put into Vidcoder and save it in either an MP4 or MKV at any size you want. Go into Encoding: settings. Select Picture & select what ever you want (you might want to keep original). Then select Video and keep Video Codec at H.264 and Framerate at same as source.
Use either Target size or Average bitrate for the size you want. Then select Audio to set the audio output you want. It may take a couple of tries to get exactly what you want, but after a couple of times you'll end up with what you want. It's now my go to converter. Any questions, just ask. -
Hi All
I have used Handbrake to convert the TS file to MP4 and transferred the file to my USB to play on TV. But on the video, at certain scenes, i get a static, popping, cracking like sound in the audio. This does not appear when i play the video on the computer, and one of my other tv's. I have tried various settings to change the audio but still get the same sound. When i use Freemake video Converter or AVC, to convert the same clip, i do not get the interference sound. So think it might have something to do with the settings in Handbrake. Any suggestions re settings to correct this or know what it may be.
Thanks. -
Hi
I've attached the text files, but not sue what i am looking for. I converted the 5.1 sound to stereo. Thought it would save space of file. Could this be the issue?
Original video.txt
Test video.txtYou won't know, until you ask -
I've checked the audio on both clips in Wavepad sound editor and they seem identical. I've now changed the Audio Codec from AAC (avcodec) to AAC Passthru and it has worked.
No interference. Albeit the size of file is a little larger keeping it Dolby Digital. i shall do a bit more trialing. Thank you.
Hi All. Re Handbrake: i have read many different comments concerning best settings to convert files.
[Attachment 48418 - Click to enlarge].
i have the attached video properties i am trying to convert and compress.
Under the Video Tab, I am confused whether i should be using the FPS as Same as Source & which setting 'Variable' or 'Constant'..or with the present 25 or 30 given and which setting 'Constant' or 'Peak'.
Under the Audio Tab, does changing the Bit rate from the default of 160 to a higher or lower make any difference to the audio. The output audio i target will be in Stereo.
Thanks. -
According to this official doc. choosing "same as source" fps with variable makes the new frame rate
identical to the original
https://handbrake.fr/docs/en/latest/technical/frame-rates.html
Also see this thread about why Handbrake mp4 encodes show up as variable frame rate in mediainfo
https://forum.videohelp.com/threads/379834-constant-variable-frame-rate-confusion-again
The response from jagabo explains it. In practical usage that small amount of jitter is nothing to worry about
160 kbps aac audio is chosen as default because it's a good compromise between size and quality -
I would leave it there -
davexnet.
Thank you for your replies. Very useful indeed.You won't know, until you ask
Split mp4 file into specified size (part1.mp4, part2.mp4 etc.)
By TubeBar in forum EditingReplies: 7Last Post: 1st Feb 2019, 22:41 -
how can i join two videos a1.mp4 + a2.mp4 = a12.mp4
By sommers in forum Newbie / General discussionsReplies: 14Last Post: 8th Jun 2017, 18:01 -
Homemade mp4 files quality vs. ripped movies in mp4 format
By MrMX in forum Newbie / General discussionsReplies: 11Last Post: 26th Nov 2015, 22:12 -
Mux AVI with MP4 / Quicktime stuff into MP4
By TheRandomOne in forum EditingReplies: 2Last Post: 13th Sep 2014, 20:29 -
Converting from MP4-AVC to AVI-MP4(xvid)
By GruntVidStar in forum Video ConversionReplies: 24Last Post: 23rd Apr 2014, 15:34
