Hey I have this great copy of the Scorpion King and I can't play it becuase it is in a ts format. How do I play this file?
what do you mean? just play it on your media player. also ts is not a file type it means either "Taped Screen" or "TeleSync". read the FAQ page on this site all of it! including how to play a movie.
We were all NEWBIES once and the only stupid question is the one that's not asked? -
Originally Posted by ygreene
B) To further the bad experience, what you have is a VCD->DivX/nAVI re-encode. IT took the already horrible FTF VCD CAM and encoded it into a lower bitrate AVI to make the worst movie quaity imaginable. In my case, i would first avoid downloading such shit. but if i did for wahtever reason get it, i'd delete it instantaneously.
if you REALLY want to watch it still, try the TOOLS section of this site to get appropriate CoDecs. -
Theres actually a few copies of the scorpion king
One by FTF which is a cam and one by centropy and theres another by uti
You probably need the divx/navi codec to play it if it doesn't work try getting another copy
And ftf isn't so bad they are getting better -
copy of Scorp stinks I have it, your better off watching it on your PC, but you will need the divx 5 codec to watch it, you can get it at divx.com.
Originally Posted by necrochain
and yes, FTF is about the worst VCD group, you might know them better as HBOVCD. who cares if they release it early? it's so shitty it's not watchable, it's better to get a good-great quality TS than a pre-CAM.
Memory card video file in .MP4 format does not play
By wakawaka54 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Feb 2011, 02:54 -
.dxa format file to other video format
By Edisonsss in forum Video ConversionReplies: 2Last Post: 2nd Dec 2010, 16:52 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
Best file format to play on Windows HTPC
By waynezo in forum DVD RippingReplies: 4Last Post: 21st Nov 2009, 15:25 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
