It seems there is no end to my problems and every time I am attempting to do something video-related I find myself asking questions here. Sorry 'bout that.
This time I was hoping to transfer some old MiniDV camcorder tapes to my DVD recorder. I don't have my old camcorder anymore, so I managed to borrow one from someone. Their camera, Sony Digital Handycam DCR-PC100E, does not have any RCA outputs. The only outgoing connections I see are Firewire, S-video and then a small yellow colored hole that looks similar to a headphone jack, and it simply is called "Video In/Out".
If I understand correctly, Firewire is only for plugging the video camera into a computer. This is not what I wish to do. I want to plug it into my DVD/BluRay recorder Panasonic DMR-BCT74.
I thought I would be able to do this through S-video. The DVD recorder only has scart input, so I ordered an S-video cable and a S-video to scart adapter. Finally today they arrived. I plugged everything in, only to find out that signal becomes black & white when plugged in through the DVD recorder.
The tapes are playing in color on the video camera's LCD display window.
What on earth is wrong and do you have any suggestions on how I should connect this video camera to my DVD recorder, to get the best possible picture quality but for the images to be recorded in color? For more information on the various inputs/outputs, here are links to the two devices' manuals:
Manual to Sony DCR-PC100E (video camera): https://www.sony.co.uk/electronics/support/res/manuals/3867/38677531M.pdf
Manual to Panasonic DMR-BCT74 (DVD recorder): https://www.manualslib.com/manual/1179140/Panasonic-Dmr-Bct74.html
Thank you so much for reading and any support in solving my latest video-problem.
Results 1 to 9 of 9
A little update. I tried to Google the problem further and if I understand correctly, the reason for the black & white images is that S-video signals are not composite-compatible? Apparently the camera originally shipped with a so-called "A/V connection cable" (see object 7 on page 13 in https://www.sony.co.uk/electronics/support/res/manuals/3867/38677531M.pdf
Does anyone know if that type of connection will work and is that my best possible bet to connect this camera to the DVD recorder? -
yes that's a composite cable for the cam. you can get them at several places still. like amazon - https://www.amazon.com/dCables-Sony-Handycam-DCR-PC100E-Cable/dp/B007I7C2RM?Subscripti...SIN=B007I7C2RM
but the only way to get the best quality off the tape would be over a firewire cable.--
You will get the best quality with a firewire transfer followed by creating a DVD on your computer.
Composite video carries the luma (greyscale) and chroma (colors) on a single wire. S-video carries the two on two separate wires. On a SCART connector the composite signal and S-video's luma are on the same pin. So if your DVD recorder is expecting composite video but the camcorder is sending s-video you will get a greyscale video. See if there is a composite/s-video setting on the DVD recorder. If there is, just set it to s-video. Otherwise, you will need to get the adapter cable mentioned in the manual. Beware that the pinouts for such adapters can vary -- so try to find the one designed for that camera.
There are also simple s-video to composite adapters that aren't optimal but usually work:
http://www.hisdigital.com/pl/product2-407.shtml
http://www.epanorama.net/circuits/svideo2cvideo.html -
Well, I went through all my cables and it turns out I had a cable like that that came with an XBOX console. I plugged it in, and the footage is now in color, BUT now there is no audio instead. LOL - the irony of fate.
As you've discovered S-video cables don't carry audio. The adapter cable should have three outputs: composite video, left and right audio.
Regarding firewire: Be sure to get a card with the Texas Instruments (TI) chip. Others often work only for hard drives, not DV/D8 camcorders.
Thanks for pointing that out. Luckily the one I am planning on ordering, PCI-E IEEE1394a (TI) (2P+1P) CARD, has just that:
Chipset:Texas Instruments XIO22313AZHH
Bus Interface:PCI-Express X1
Compliant with PCI Express Base Specification 1.0a
Compliant with IEEE 1394-1995, 1394a-2000 and OHCI 1.1 Standards
PCI Express 1-lane(x1) FireWire adapters works with PCI Express slots with different lane width
Installs in any available PCI Express slot and supports data transfer rates up to 400Mbps
Two external and One internal 6-pin FireWire(1394a) ports to support DV camcorders, hard disk, removable drives, scanner, digital cameras and other FireWire audio/video devices
Onboard power connector to provide reliable source
I'm hoping it will work.
Movavi Screen Recorder Suite 9 - Audio will not record
By Uncle Joe in forum Newbie / General discussionsReplies: 1Last Post: 13th Jun 2018, 18:40 -
Toshiba D-VR4XSU HiFi Video Cassette Recorder & DVD Recorder / Player VCR
By fmitchelltx in forum Newbie / General discussionsReplies: 3Last Post: 9th Apr 2016, 22:40 -
Cannot record from SD card to Blu-ray recorder HDD
By JBR in forum Newbie / General discussionsReplies: 11Last Post: 5th Jun 2015, 08:31 -
Attempting to download HLS video from gyao
By jiffykornn in forum Video Streaming DownloadingReplies: 4Last Post: 21st May 2015, 06:49 -
lg hdd/dvd recorder lrh-880-how to copy/record from disc/hard drive
By waynebyron7 in forum FeedbackReplies: 2Last Post: 5th Mar 2015, 14:33
