I'm trying to burn in subtitles, using Virtual Dub Mod and loading VSFilter in my script.
If I simply mux my video and the subs to a mp4 or mkv, it plays just fine and is in sync.
But when I import the video and the sub file to Virtual Dub Mod, it is not in sync anymore - the video is faster than the subtitles.
Because it seems to get more async the more time passes, I assume it has something to do with the framerate. But the original video file's framerate is 23.976 and that's what I set Virtual Dub Mod to aswell. When I mux the original file's audio with the virtual dub mod encoded video, those are in sync, just the burned in subtitles are not.
They are already not in sync anymore in the preview after loading my script.
There's nothing fancy in the script, that could change the framerates - just loading the video, then some visual filters like saturation and sharpening and at the end it loads VSFilter and the .ass file.
Can it be that Virtual Dub Mod changes the framerate of the subs by itself due to some settings? Or do I have to set the subs framerate in the script?
Always worked fine before, so I don't know what's going wrong this time.
Results 1 to 9 of 9
I wrote a quick encoding .bat using ffmpeg just for hardcoding subs without any filters or anything and that worked fine.
So it really seems to be some kind of settings issue with virtual dub mod and megui. What kind of settings could mess with the subtitle speed?
Sorry, I don't have telegram. -
Yes, I used handbrake to create a lossless source file and made sure it's set to constant framerate. When I look up the media info of the source file on my player it also says the framerate mode of the video stream is constant.
I found the issue by myself and managed to fix it.
Virtual Dub Mod somehow detected the wrong framerate on the video and imported it and the subs with 25 fps. It seems to automatically match the subs to that framerate it detects. Because I manually set the video framerate in virtual dub mod to the right one (23.976) after importing, the video was encoded with the right framerate but the subtitles were not.
In order to fix that, I added a line in my .avs script:
assumeFPS(23.976)
So now it loads the video with the right framerate to begin with, the subtitles are imported with the same framerate and I don't have to manually adjust anything anymore after importing.
video into Virtual Dub
By lovebug in forum Newbie / General discussionsReplies: 2Last Post: 2nd Oct 2017, 06:25 -
AVISynth and virtual dub
By martin. in forum Video ConversionReplies: 7Last Post: 7th May 2016, 02:38 -
Virtual Dub Mod won't open PGC Demux
By loninappleton in forum Video ConversionReplies: 10Last Post: 1st May 2015, 22:40 -
Virtual Dub- audio sync
By shokan22 in forum Newbie / General discussionsReplies: 8Last Post: 23rd Oct 2014, 01:23 -
Need 5.1 encoders for virtual dub
By Artas1984 in forum Video ConversionReplies: 5Last Post: 20th Oct 2014, 12:56
