Hi everyone and Happy New Year!
I'm looking for a solution where I can add a m2ts file to an existing bluray playlist but so far haven't found much information. I'm assuming that it's not that complicated if one knows what they're doing so I'm little surprised there's almost no information about it.
From what I was able to gather is create a bluray structure for the additional clip with Tsmuxer and then from that structure copy the clipinfo and stream files into the respective folders of your original bluray structure. Then you should edit the playlist in the original structure possibly with BDedit so that the added stream file is recognized and here is where I'm stuck.
Can someone give me a step by step instruction on how to link a newly added stream to a playlist? Perhaps, there's even a tool that makes this a breeze. In any case thus far I wasn't able to find any info.
Thanks in advance.
Results 1 to 1 of 1
Adding Subtitle tracks to existing DVD and BD ISOs
By solkap in forum Newbie / General discussionsReplies: 11Last Post: 7th Dec 2018, 22:54 -
M2ts files and Bluray Menu?
By malimuc in forum Authoring (Blu-ray)Replies: 6Last Post: 8th Jun 2017, 09:27 -
Merge BluRay playlist to single m2ts?
By Numinel in forum Authoring (Blu-ray)Replies: 4Last Post: 6th Jun 2014, 02:01 -
Potplayer: adding files to desired position in playlist.
By qwecxz in forum Software PlayingReplies: 5Last Post: 3rd Feb 2014, 23:02 -
PgcEdit..adding new button to existing menu.
By sambat in forum Authoring (DVD)Replies: 7Last Post: 16th Jan 2014, 13:08
