I have been burning VCD's with Win On CD and have found it difficult to get the autorun feature to autoplay my VCD's on PC. Could someone please give the procedure to properly autoplay VCD's?
Thank You,
mirish
1- select your project Video CD or Video CD Xtended
2- In TRACK mode Video CD 2.0 Filesystem right click PROPERTIES, then select CHECKBOX:
CD will contain a software VideoCD player for Windows, if you
want you can select application for CD-I players too,
but its optional. Click OK.
3- Still in TRACK mode ISO9660 [TItle] right click PROPERTIES, the select the
tab AUTORUN, Check GENERATE autorun.inf, then click "modify autorun settings"
and select the tab autoplay, write: Vcd_play.exe
click ok and again ok.
Voila... that´s all..
If you want to check before you burn the cd if the autorun.inf is ok, click on
ISO9660, then Editor, you´ll see a directory tree.
Hint: if you want to add a readme.txt just drag and drop at same level of
autorun.inf
Cardosi
Advise needed how to create a 768x1024 (portrait!) H.264 MOV for iPad
By pixelpartner in forum ffmpegX general discussionReplies: 2Last Post: 4th Nov 2010, 11:25 -
Autorun Powerdvd in MCE2005
By alucard2050 in forum Software PlayingReplies: 0Last Post: 23rd Feb 2010, 19:30 -
Autorun Precedence - DVD & Autorun on the same disc
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2007, 20:26 -
How to make an autorun VCD in English please!
By jimiir in forum Authoring (VCD/SVCD)Replies: 10Last Post: 8th Aug 2007, 22:56 -
how to create VCD protection?
By C-W in forum Authoring (VCD/SVCD)Replies: 4Last Post: 18th May 2007, 12:00
