Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
    Jan 2008
    Each one is about 1.5GB. What program can a newbie like me use and preserve the menus. Also can this be done without re-coding everything?
    Thanks!
  2. It is very easy to do a compilation of several movies only (for example with DVDShrink), but it is very difficult to preserve the menus, as they use the same registers to store their values, and that cause conflicts. It is theoretically possible to do that with PgcEdit, but that requires a long learning curve. Otherwise, IIRC, that was possible with DVDFab, but I can't find the right tool any more, and the guide has been deleted from their site, so I don't know if it's still supported. And anyway, DVDFab is not free.
    Sorry, I can't help much more.
    r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
    - BD3D2MK3D A tool to convert 3D BD to 3D SBS/T&B/FS MKV
  3. DvdReMake used to do this. However I'm not sure of the status of the program.
