I'm completely new with VSDC and need a little help.
I shot some video with my iPhone and synced it to my Win 10 PC and iPad. I do this by moving the file (video or photo) from the camera folder to an album after it's synced on the PC. I then resync and the video/photo is in the appropriate album on the iPad/iPhone.
Recently I wanted to simply remove the audio from one of the videos and found VSDC. I started a project, loaded in the video, removed the audio and saved the project as a .mov. I can see and play the video with any of the "regular" Win programs and the audio is removed.
However, this file does not sync when I sync with iTunes.
I then tried saving as a .avi, just to see if this would sync. It also does not sync.
Any guidance into what silly mistake I am making is greatly appreciated.
VSDC version is 6.3.1.924, iPhone/iPad iOS 12.1
Thank you for the quick response.
I had tried something similar to your suggestion. I had another video that was oriented 90d off, so I rotated it and saved it (with the original audio untouched). This new file also did not sync.
However, playing around with VSDC, I noticed that there are selector buttons to save files (PC, Web, iPhone/iPad, DVD,...). PC was selected. So, I selected iPhone/iPad. This saved the file as .m4v instead of .mov or .avi (which were options on the PC selection).
For whatever reason, this format worked to sync the files. I find it interesting in that when you record video with your iPhone/iPad the format (as shown on the PC) is .MOV. The .m4v does play on the PC, so I can live with the format.
I have no idea why the "PC"/.mov or .avi files do not sync. But at least I have a workaround.
Thanks again for the help. -
I use a non-Apple app to add music and video to my iPhone. AirDisk Pro.
https://itunes.apple.com/us/app/airdisk-pro/id505904421?mt=8 -
Thank you for the recommendation. Because of my 60 year old eyes, I prefer the 42" 4k monitor on my PC
Syncing iTunes between two Macs Help Please
By maverickluke in forum Newbie / General discussionsReplies: 3Last Post: 26th Jun 2018, 18:28 -
iPhone/iPad movie time stamps?
By terrypin in forum Newbie / General discussionsReplies: 7Last Post: 10th Jun 2017, 04:39 -
FFMpeg Presets for Video Format/Quality and Device (Iphone,Ipad e.t.c.)
By alexander121 in forum Video ConversionReplies: 2Last Post: 25th Nov 2015, 04:25 -
delete iphone songs/videos WITHOUT itunes
By angryassdrummer in forum Portable VideoReplies: 15Last Post: 24th Apr 2015, 12:16 -
Do you rip/encode DVDs into separate AppleTV, iPad and iPhone m4v files?
By bobogs in forum DVD RippingReplies: 3Last Post: 24th Sep 2014, 11:42
