    Apr 2018
    Sunsari [Nepal]
    Hi, Thanks For All Team Members Who Support Me A lots,
    I Want to Know About Which Software Can Make Thumbnail Exactly Like MPC-HC, I Really Like MPC-HC, Because of Very Good Ouput, I had Tried a Lot of Thumbnail Maker and Not Satisfied, And I Have Some Small Small Episode and Want to Make a Single Thumbnail From More Than 1 Video Clips,
    Please take a Look I Found a Thumbnail,
    https://3.bp.blogspot.com/-G7pkJbtXp00/XDQVQQrsR1I/AAAAAAAAkeQ/tpatmFaxn5E-0DmvMDCNfAQ...01HV72.mkv.jpg
    Will Anyone Please Tell Me Which Software is used to Make This Thumbnail
  2. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    Sorry, I cannot pinpoint that exact tool but...
    If you wish to pull a thumbnail every so many frames, you can use FFMpeg and the 'Tile' Filter:
    https://trac.ffmpeg.org/wiki/How%20to%20take%20multiple%20screenshots%20to%20an%20imag...le%2C%20mosaic)
    If you wish to do the same with videos, showing several at once , you can use the overlay in FFMpeg:
    https://trac.ffmpeg.org/wiki/Create%20a%20mosaic%20out%20of%20several%20input%20videos
    If you want to use multiple images from different sdources, FFMpeg and Tole
    https://superuser.com/questions/625189/combine-multiple-images-to-form-a-strip-of-images-ffmpeg
    Last edited by Budman1; 9th Jan 2019 at 00:09. Reason: Added different source example
    Apr 2018
    Sunsari [Nepal]
    Thanks to All, Exactly i Found What I Looking For,
    Above Attached Thumbnail Are Generated By Video Thumbnails Maker
