Results 1 to 13 of 13
    Oct 2015
    Dublin
    Hello!
    Can anyone tell me what free program may I use to substitute WINRAR?
    Thank you.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I use 7Zip sometimes.
  3. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    7zip is all I use. It's free and it's the best imo, also supports unpacking just about anything anyone uses.
  4. What about Windows' built in ZIP support?
    Jul 2007
    I use Bandizip in additon to 7-Zip as it works on some files that 7-Zip won't.
  6. 7Zip here also.
    Extraordinary claims require extraordinary evidence -Carl Sagan
  7. ½ way to Rigel 7 cornemuse's Avatar
    Mar 2014
    Cyber Dystopia
    7Zip, , , , ,
    Yes, no, maybe, I don't know, Can you repeat the question?
  8. In addition to 7-Zip, another free one is PeaZip:
    http://www.peazip.org/download-installer-p-windows.html
    Oct 2015
    Dublin
    Thanks to everyone that helped me.
    But now I have a problem: When I have a zip file and click it with the right mouse to open the menu and choose
    " Open with " it doesn't appear the name 7z to select the program. What must I do?
  10. You associate 7-Zip to all supported filetypes. Open 7-Zip with Admin rights and set up in options.
    But in right click menu there should be already a new entry. You don‘t need open with. Did you install the x64 exe?
  11. Hi ,
    I use "IZArc.exe" under XP (32bits) .
    Some times 7-Zip .
    Cheers .
    JE SUIS CHARLIE !!!
    Nov 2016
    Los Angeles, USA
    After installing 7Zip, you should be able to see the "7-Zip" context menu when you right-click a .zip file in Windows Explorer.
    Oct 2015
    Dublin
    Thank you to everyone who answered me.
    I managed to solve my doubts.
