I'm trying to accurately cut massive HD video but the program keeps crashing. Can the program just not handle the resolution?
Smart Cutter PS/TS supports 1920 x 1080 video, but not every possible type of 1080p video. You need to tell us more. What kind of file is it? What type of audio and video does it contain? A MediaInfo report might help us answer your question. Open the file and select "Text" from the View menu, then cut and paste the results into a post in your thread.
What produced this video? Most editing software has trouble with variable frame rate video (such as cellphone video) and with some transport streams recorded from TV broadcasts, which may have corrupt frames or missing frames or other irregularities.
Also, Smart Cutter PS/TS like other editing software doesn't support every type of audio and video. For example, MPEG-2 or H.264/AVC video is supported but not H.265/HEVC, and AAC or DolbyDigital/AC3 audio is supported but not DTS and Dolby TrueHD.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (isom/iso2/avc1/mp41) File size : 639 MiB Overall bit rate mode : Variable Overall bit rate : 5 213 kb/s Encoded date : UTC 2018-02-12 18:04:00 Tagged date : UTC 2018-02-12 18:04:00 Writing application : HandBrake 1.0.7 2017040900 IsTruncated : Yes Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings, CABAC : Yes Format settings, RefFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Bit rate : 4 959 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 59.940 FPS Minimum frame rate : 59.920 FPS Maximum frame rate : 59.960 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.040 Stream size : 608 MiB (95%) Writing library : x264 core 148 r2708 86b7198 Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=34 / lookahead_threads=5 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=1 / keyint=600 / keyint_min=60 / scenecut=40 / intra_refresh=0 / rc_lookahead=30 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00 Encoded date : UTC 2018-02-12 18:04:00 Tagged date : UTC 2018-02-12 18:04:00 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio #1 ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Bit rate mode : Variable Bit rate : 111 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Stream size : 13.5 MiB (2%) Title : Stereo / Stereo Language : English Default : Yes Alternate group : 1 Encoded date : UTC 2018-02-12 18:04:00 Tagged date : UTC 2018-02-12 18:04:00 Fallback From : 3 Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Format settings, Endianness : Big Codec ID : ac-3 Bit rate mode : Constant Bit rate : 128 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 15.7 MiB (2%) Title : Stereo / Stereo Language : English Service kind : Complete Main Default : Inherited From: 2 Alternate group : 1 Encoded date : UTC 2018-02-12 18:04:00 Tagged date : UTC 2018-02-12 18:04:00 Fallback To : 2
I don't use Handbrake very often, but I know that it produces variable frame rate video using its default encoder settings. (The MediaInfo report for your video says it was encoded using Hanbrake and uses variable frame rate.) Every video editor that I have heard of has problems with variable frame rate video.
If you encoded this video yourself, you could try encoding the source again using Handbrake's constant frame rate setting to see if that makes any difference when editing with Smart Cutter PS/TS.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
I use Smart utter for editing TV recordings in 1920x1080 recorded via a Hauppuge HDPVR2 box. I have frequently had problems seeking with the program crashing on either a fast forward click or a movement of the fine scroll slider. I believe I pinned this down to changes in the audio format during the recording as this usually occurs when the main recording is Dolby 5.1 and some of the adverts or pre and post video are just stereo (or vice versa). I have just found that turning off "Enable Audio View Mwter" under the Options button appears to reduce these crashes I haven't had a crash since doing so.
Smart cutter is working well for me now with Enable Audio View Meter turned off and I'm used to it so I will continue using it. It gives me frame accurate editing with only the transitions re-encoded so quality is very well maintained.
Smart Cutter 1.9.3
By erzane in forum EditingReplies: 7Last Post: 21st Jan 2016, 17:07 -
1920x1080 vs full screen in VLC Media player on 1920x1080 screen
By Circlotron in forum Software PlayingReplies: 4Last Post: 17th Apr 2015, 07:16 -
Smart Cutter for DV and DVB crashes
By jamespoo in forum EditingReplies: 10Last Post: 27th Dec 2014, 17:13 -
H264 video cutter with smart re-encoding (alternative to VideoRedo H264)
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jul 2014, 09:42 -
Projecting 1920X1080 video
By Saramack in forum Latest Video NewsReplies: 23Last Post: 24th Jun 2014, 21:59
