I have a Toshiba DVR7 DVD/video combo. I spent quite a bit of time converting all our home videos onto DVDs using this device, and they playback beautifully on our TV. The problem arose when I went to convert the DVDs to a USB/ computer hard drive. None of our computers with a DVD player can read the disks. I even bought an external DVD drive for our computer but it still won’t read the DVDs. What have I done wrong? Has anyone encountered this problem? Is there a computer program I can download that will read the DVD?
You bought the cheapest discs you could find. You might be able to recover some of the content with ISO Puzzle.
If a DVD recorder can play the DVDs it created but a computer can't find any files or folders on the DVD, the most common explanation is that the discs were never finalized by the recorder. This is a separate step which closes the disc to writing and creates a menu which allows other DVD players and DVD player software on a computer to read and play the DVD. If you still have the Toshiba DVR7 you can finalize the DVDs. Otherwise, you will need to use a specialized data recovery program for optical media to retrieve your recordings.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Video Recording Mode instead of Video Mode on the dvd-recorder ?
Thank you usually_quiet. I will go back and see if I missed a step somewhere.
can't install Asmedia usb 3.0 driver/USB 3.0 Host Controller not found
By clashradio in forum ComputerReplies: 18Last Post: 28th Sep 2017, 10:05 -
AverTV USB HD DVR or Hauppauge USB HD PVR
By gll99 in forum Capturing and VCRReplies: 34Last Post: 8th Jun 2015, 10:56 -
DVD on USB flash drive
By jjis in forum Newbie / General discussionsReplies: 28Last Post: 13th Oct 2014, 12:09 -
Best way to transfer data between two computers? usb cable or usb hdd?
By yoda313 in forum ComputerReplies: 19Last Post: 9th Feb 2014, 10:45 -
Can a USB powered DAC filter out power supply noise from the USB line?
By MarcMiller in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2014, 04:37
