Hello,
I am having issues working with HEVC video in tsMuxer. Resulting files seem to be corrupted and unplayable. PotPlayer reports the final file (m2ts) to be 3 hours long and will freeze player when you try to get past ~1h 30 minute mark. If ran from mpls file, the movie is only 1h 31 minutes long, unlike proper duration reported by MediaInfo. Playback speed seems to be broken - movie will play good for like one second to quickly skip next few frames and repeat.
Any ideas what's going on here? I am attaching some logs.
tsMuxer seems to be only reporting these things:
Original file:Code:HEVC stream doesn't contain fps field. Muxing fps=23.976 B-pyramid level 2 detected. Shift DTS to 3 frames
Remuxed file:Code:Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High Codec ID : 36 Duration : 1 h 46 min Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (23976/1000) FPS Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709
Code:Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High Codec ID : 6 Duration : 1 h 46 min Bit rate : 56.2 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (23976/1000) FPS Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.283 Stream size : 42.0 GiB (96%) Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709
Results 1 to 1 of 1
Hevc
By kirkmc in forum Software PlayingReplies: 3Last Post: 15th Jun 2018, 23:49 -
[hevc] Unknown HEVC profile: 0
By Randombit in forum Software PlayingReplies: 8Last Post: 25th Jul 2017, 13:26 -
FFDSHOW for HEVC
By Zee530 in forum Newbie / General discussionsReplies: 10Last Post: 7th Jul 2017, 15:49 -
what Is HEVC
By Aashik Alam in forum Video ConversionReplies: 1Last Post: 28th Feb 2016, 21:00 -
nvenc hevc
By madhatr in forum Video ConversionReplies: 4Last Post: 19th Dec 2015, 19:07
