I have a cartoon DVD which is 23.976 but telecined to 29.97 using soft and hard telecine. Here's a sample:
VTS_03_1.demuxed.m2v
But I have issues. This is what happens when I use normal TIVTC/TDecimate, nothing else:
Code:MPEG2Source("VTS_03_1.d2v") ConvertToYV12() TFM(D2V="VTS_03_1.d2v") TDecimate(Mode=1)
Any ideas?
Results 1 to 13 of 13
Perhaps this:
LoadPlugin("J:\StaxRip_1.1.9.0\Applications\DGMPGDec\DGDecode.dll")
Load_Stdcall_plugin("J:\StaxRip_1.1.7.2\Applicatio ns\AviSynth plugins\Yadif\Yadif.dll")
import("F:\Program Files\AviSynth\plugins\srestore.avs")
mpeg2source("C:\Users\davex\Desktop\avs_test\VTS_0 3_1.demuxed.d2v")
yadif(mode=1)
srestore(frate=23.976) -
The chroma on your video is messed up. The yadif+srestore method will probably take care of most of the blended chroma problems. Qtgmc+srestore will give less deinterlacing artifacts if you can stand the slow processing.
Code:mpeg2source("VTS_0 3_1.demuxed.d2v") QTGMC(preset="fast", sharpness=0.7) SRestore(frate=23.976) -
Very weird - chroma is telecined separately from luma... - perhaps separating chrominace and processing separately will help.
except chroma works nicely.Code:"fieldmatch=order=auto:combmatch=full, yadif=deint=interlaced, decimate"
That is part of the GRunT package.
http://avisynth.nl/index.php/GRunT
SRestore lists several other required packages. Did you have those?
http://avisynth.nl/index.php/Srestore#Required_Plugins -
Help with cartoon (ghosting, interlacing)
By Vitality in forum RestorationReplies: 8Last Post: 22nd Nov 2018, 20:31 -
HandBrake: Ghosting/Interlacing issues? First time this has happened to me.
By GoodLucker in forum Video ConversionReplies: 3Last Post: 12th Oct 2017, 20:14 -
I cannot tell if this clip is Telecined or not...
By Lathe in forum RestorationReplies: 20Last Post: 7th Nov 2016, 01:41 -
Deinterlacing inverse telecined video
By Colek in forum Video ConversionReplies: 4Last Post: 9th Aug 2016, 09:51 -
Advice for hard telecined, variable framerate DVD?
By xAlienxx in forum DVD RippingReplies: 16Last Post: 16th Dec 2014, 17:26
