I want to convert Video files so I can play them on my TV. Is there a free file converter and if not what would be the best one to buy?
The best answer to these types of questions is always, get a standalone Android box of <$50 as it will run rings around the builtin player on your TV. Far better than cutting a square peg into a round hole.
If you insist on playback on your TV directly, list what types of files the media player in your TV will work with and list the types of files (with Media Info reports) you have. The fix could be something as simple as fixing the header to complete reencoding (losing quality and taking time) to a format the media player in your TV will accept. With this, others will be able to suggest the best software to do what you need to do.
Converting files for Roku
By BugMagnet in forum Video ConversionReplies: 15Last Post: 20th May 2020, 12:57 -
Converting sup files onto srt
By carlmart in forum SubtitleReplies: 12Last Post: 6th Jun 2016, 16:49 -
Converting .WTV Files
By ryangarfield in forum Video ConversionReplies: 22Last Post: 27th Nov 2015, 06:31 -
Converting MPEG-2 files
By martyr.kerplunk in forum Newbie / General discussionsReplies: 6Last Post: 15th May 2015, 02:12 -
Converting PCT files
By Jeikobu in forum MacReplies: 3Last Post: 8th Jul 2014, 11:16
