Hi!
I´m interested in working with the analog signal from my camcorder, recording it as audio, manipulating it and export/encode it as sd video.
Is this possible?
IE; Not using a capturing device but rather audio input.
Best Regards
Alexander
A baseband video signal contains frequencies up to 4 MHz. Audio circuitry is designed to handle frequencies up to 20 kHz.
Well... if you can slower your video 625 times then yes... As already mentioned audio input will allow you to capture video with resolution of single line (imagine video like 1.408 pixel wide and 625 lines tall) There is possibility to use audio signal to transfer very high resolution video (or rather pictures) and it is called SSTV - theoretically if you have plenty of time then you can capture video with audio input. (Sample&Hold circuit + still frame buffer + synchronization circuit responsible for selection successive points in line).
as video is not different than audio (i mean difference is 2d vs 1d) then you think about transferring audio as video and video to audio - for example https://ffmpeg.org/ffmpeg-filters.html#spectrumsynth - you can use graphic editor to change audio (apply filtering etc).Last edited by pandy; 5th Jan 2019 at 13:08.
Customizing PotPlayer interface for Audio Playback
By potuser in forum Newbie / General discussionsReplies: 6Last Post: 3rd Mar 2020, 09:05 -
VHS PAL Capture - Very minor pink noise appearing on sports capture
By Robertp in forum RestorationReplies: 12Last Post: 9th Nov 2018, 19:50 -
Panasonic DMR-ES40V video interface issue
By buck116 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 31st Aug 2018, 12:04 -
Capture PAL Video-8 with NTSC Sony TRV520 over Firewire?
By LisaClark in forum Capturing and VCRReplies: 4Last Post: 27th Oct 2015, 08:05 -
Problems adding PAL audio track to NTSC video, both with the same duration
By Swordmaster512 in forum Newbie / General discussionsReplies: 5Last Post: 27th Jul 2015, 20:51
