I have a project for which I am attempting the following steps:
1) Extracting 5.1 DTS audio files from MKV files with MKV Cleaver.
2) Converting the audio to 6 channel WAV files using convertio for the purpose of editing in Audacity.
3) Edit the WAV file in Audacity.
4) Use Audacity to export the new 6 channel WAV files.
5) Reconverting the audio back to DTS on convertio.
6) Remuxing the new DTS file with the h.264 video stream from the original MKV using MKVtoolnix.
I've done all this successfully with a few shorter clips. But now I'm running into a problem.
For the third clip of the project, when I get to step four from above, It only seems to be exporting the first channel to the new WAV file.
The third clip is definitely the longest one, nearly 25 minutes, but I wouldn't think that would make any difference other than taking longer to export. And I'm pretty sure I'm using all the same settings I was using when the exports were successful, including making sure "Use custom mix" is selected under Edit -> Preferences -> Import/Export.
Any brainstorms as to a reason why Audacity would suddenly not be combining all the tracks into the new WAV file?
I'm happy to provide screen shots of the "Part 3" of the project, and/or any of the settings thereof, if that would be helpful in some way.
Thanks for any help!
Results 1 to 1 of 1
Converting TrueHD Atmost track to Dolby Digital + Atmos track?
By illuvattarr in forum AudioReplies: 2Last Post: 22nd Jul 2018, 00:09 -
What Editing Software for multi-track audio
By Droidling in forum Newbie / General discussionsReplies: 16Last Post: 2nd Feb 2018, 06:11 -
How do I (BATCH) set a specific subtitle track, and audio track as default?
By MountainSplash00 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Dec 2014, 07:53 -
Software for syncing and muxing audio track with video track?
By uranometria in forum Video ConversionReplies: 1Last Post: 21st Jul 2014, 02:52 -
How to re-encode a multi video track mkv?
By sveno in forum Video ConversionReplies: 4Last Post: 15th Apr 2014, 05:38
