Results 31 to 34 of 34
Not playing around, and yes, striped RAID (0), or striped and mirrored (10). It can be a 2x, 3x, 4x boost depending on how you stripe it (minus some overhead). Not cheap, but it does work.
Scott -
Fair enough. I seriously thought you were playing around because the OP seems to be looking for low cost workaround for what he wants, which RAID definitely isn't as you've stated.
I know people have done / do it, but it seems that running a RAID through USB or Thunderbolt is a waste of the speed gain (which of course is still quicker than a single drive). -
USB2 no way. USB3.0 maybe, USB3.1/USB-C or Thunderbolt (2 or better 3), should be OK. On Mac side, there are high speed data (esp. video) solutions specifically designed around externals using Tb3, some of them RAIDed. LaCie is usually one of these, though I haven't checked them out recently.
If the OP is looking for HIGH PERFORMANCE and HIGH QUALITY & RELIABILITY and HIGH PORTABILITY and LOW COST, they won't find it. Something's gotta give - which one(s) depends on one's priorities.
Multiple capture cards and DVs run the system at the same time?
By 280634157 in forum Capturing and VCRReplies: 0Last Post: 14th Apr 2018, 09:24 -
Portable video capture system
By uvwid in forum Capturing and VCRReplies: 3Last Post: 10th Apr 2018, 19:52 -
Dedicated TBC
By mountaincabbage in forum RestorationReplies: 1Last Post: 19th Apr 2016, 17:00 -
Hdmi capture card for the system?
By michael_j in forum Capturing and VCRReplies: 3Last Post: 18th Mar 2014, 09:05 -
VHS conversion: dedicated converter or PC?
By OM2 in forum Newbie / General discussionsReplies: 9Last Post: 15th Jan 2014, 17:38
