Disk Utility is no longer available for this since the High Serria. Any other options available for Mojave?
	Probably better asked and answered in our Mac Forum. Moving you.
 And welcome to our forums.
	I suppose you meant to say that the BootCampAssistant is no longer available. It actually is on some machines, but it was deactivated for the Classic Mac Pro tower computers. The reasons are valid, but you can still run windows. I have windows 10 installed on my system without issue.
 If you are in fact using a cMP tower, you shouldn’t install from a USB. The USB install is an EFI Windows install and it can (and has for many people) cause firmware corruption which will give you a giant silver brick on your desktop. You should only install windows 10 in legacy mode from a DVD (default option for DVD). It’s not hard, and it won’t brick your machine. If you still insist on installing in EFI mode, the informaion below should help. Forget about BCA (BootCamp Assistant), it’s simply not needed.
 A quick Google of the subject leads me to the page below. I hope this helps.
 https://www.passfab.com/mac/how-to-create-a-bootable-windows-10-8-7-usb-on-mac-with-wi...-bootcamp.htmlLast edited by crjackson; 2nd Jan 2019 at 22:58.
	Thanks for this great suggestion.
 Bootcamp is available on my mac but it keeps saying the USB should be 32G+. However, I only got a 16G USB sticks. I am trying to use PassFab software but the disk is not bootable. Now it is no longer an issue as it is fixed by following the tips in this post: https://www.androidphonesoft.com/resources/burn-iso-to-usb-on-mac.html
  Mac Book Pro: Make full length videos and put them on a USB stick?By MagicDrop in forum Newbie / General discussionsReplies: 7Last Post: 3rd Oct 2018, 15:51
  BD Player that will play folders/iso from USB including menus?By JoeKlein in forum DVD & Blu-ray PlayersReplies: 16Last Post: 9th Dec 2017, 00:27
  Installing Windows 7 from USB stick in VirtualBox in Windows 7 HostBy Keyser in forum ComputerReplies: 11Last Post: 14th Mar 2016, 22:05
  Mac and Handbrake CLI - ISO to MKVBy TaT-DK in forum MacReplies: 2Last Post: 13th Jun 2014, 04:40
  ATI 600 USB TV Wonder does not work with Windows 7 or Windows 8By MrTemplar in forum Capturing and VCRReplies: 11Last Post: 23rd Apr 2014, 09:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
