Hi,
I'm using MPC-HC 1.8.4:
https://github.com/clsid2/mpc-hc/releases
MPC-HC has format-specific icons, showing you different icons according to file type, such as "AVI" icons for .avi files. However, sometimes the settings don't do anything, and I keep seeing the generic "321" icon for any filetype associated with MPC-HC. The format-specific icons are all saved in mpciconlib.dll in the MPC-HC directory, and the file is there alright. I've already tried reassigning the filetypes, and re-saving the setting in MPC-HC's options "use format-specific icons" (or something like that), rebooting the computer, all to no avail.
Any ideas how to fix this? Thx
Results 1 to 1 of 1
I'm OddTheodora. I'm open for everyone, and I'm for free.
"Invalid SRT format. "06B20BF0" is invalid timing info" error with tsMuxeR
By Jijital in forum Authoring (Blu-ray)Replies: 6Last Post: 3rd Feb 2016, 00:18 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 07:21 -
Avidemus 2.6.6: output format mpeg-PS-Muxer, What is "Configure: free" for?
By MovingParts in forum EditingReplies: 1Last Post: 8th Jun 2015, 10:42 -
Is there a way to "Paste" MPC-HC shader effect to a video?
By Unknown01 in forum Newbie / General discussionsReplies: 4Last Post: 5th Jun 2015, 16:30 -
[Help] Problems with the "Title Button" in the "VTS ROOT" and "VTS Normal"
By kirous in forum Authoring (DVD)Replies: 8Last Post: 1st Nov 2014, 12:31
