Hi guys,
There is a problem about 2.5 years long that on some mkv files subtitles were not showing. Very weird bug, because it was depending on file location, if file, for example, was on e: potplayer didn't show subtitles, but if the same file was located to d: disc, potplayer did show subtitles.
I saw a lot of topics with this problem, but there was not working solution in there. I used an old player version for a while, but someday I became too desperate and tried to find the reason caused such behavior. And I found it! The "SeamlessPlay=1" setting in config file, which seems to be obsolete, caused subtitles not showing. If you delete this line, subtitles will work fine.
I have already published this on PotPlayer forum, but beacuse your forum is better indexed by Google, I duplicate it here for some people to find it useful.
Results 1 to 1 of 1
PotPlayer: Advancing the Playlist issue
By lemings in forum Software PlayingReplies: 1Last Post: 22nd Jun 2017, 13:40 -
Potplayer subtitle language issue
By Chaffee in forum Software PlayingReplies: 6Last Post: 10th Dec 2016, 11:41 -
PotPlayer Subtitle Alignment Issue.. Help Please
By FurqanHanif in forum Newbie / General discussionsReplies: 6Last Post: 1st Jan 2015, 05:27 -
Potplayer - aspect ratio issue
By rigger67 in forum Software PlayingReplies: 4Last Post: 13th Apr 2014, 11:19 -
Issue with MadVR in Potplayer
By wolfman2791 in forum Software PlayingReplies: 3Last Post: 26th Feb 2014, 09:50
