So in my quest to record NTSC footage on my PAL Digital8 camcorder (which, if you don't know, can record an NTSC stream from FireWire without trouble, my computer simply refuses to send it), I downloaded GraphStudioNext. I'm able to stream PAL DV to the camcorder without trouble, but when I try it with NTSC video, it says "format incompatibility." Well, actually, when I try to connect the AVI splitter to the camcorder, it says "No combination of intermediate filters could be found to make the connection." Long story short, I now realize that the problems I've been having are due to the input pin on the camcorder's DirectShow filter being incompatible with NTSC data. The filter "expects" PAL data as an input.
So does anyone know how to bypass that and allow the filter to accept NTSC or PAL DV?
Alternatively, does anyone know of any devices on the market that can play DV-AVI from an SD card through FireWire? Like an SD-card-based DV recorder/player?
Results 1 to 1 of 1
How to set resolution (720x576) in graphedit / graphstudionext?
By spotty in forum Capturing and VCRReplies: 3Last Post: 10th Dec 2018, 19:19 -
How do I bypass a still menu?
By Instant Martian in forum DVD RippingReplies: 16Last Post: 2nd May 2017, 09:06 -
How to bypass admin password?
By aruwin in forum ComputerReplies: 6Last Post: 29th Sep 2015, 00:06 -
Bypass Referral
By evilfalcon in forum Video Streaming DownloadingReplies: 0Last Post: 12th May 2014, 01:49 -
Roxio game capture hd pro and graphstudionext
By Milardo in forum Capturing and VCRReplies: 9Last Post: 10th Jan 2014, 22:34
