Hi,
I have MKV movies that are HDR 4K with True DTS or DTS-MA and I want to rip only the sound, some of them have communitaries which I also want to remove.
How can I do it ? I want to have the original Audio track 24bit 48000 True-DTS and be able to move forward or backward while it's playback. Cause I made it to get the file as THD file, but I can't find a way to edit it before or after and I can't move forward or backward , it just play it back from start to end, can only pause.
I took the programs from the thread here . Hybrid works fine but it keeps the communiatries audios also , and there is no way to edit in the program or at least from what I tried .
https://forum.videohelp.com/threads/359357-Extract-DTS-MA-from-MKV-in-highest-quality-...FLAC-or-PCM%29
Hi , thanks
ok I wrote it like you said without the @set .
I am getting this thing
title : Dolby Atmos/TrueHD Audio / 7.1-Atmos / 48 kHz / 5212 kbps / 24-bit
BPS-eng : 4572106
DURATION-eng : 01:44:49.284000000
NUMBER_OF_FRAMES-eng: 7547141
NUMBER_OF_BYTES-eng: 3594409818
_STATISTICS_WRITING_APP-eng: mkvmerge v22.0.0 ('At The End Of The World') 64-bit
_STATISTICS_WRITING_DATE_UTC-eng: 2018-04-06 18:22:01
_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
encoder : Lavc58.35.100 flac
[out_0_0 @ 000001e50f29b8c0] 100 buffers queued in out_0_0, something may be wrong.
size= 205568kB time=00:08:31.68 bitrate=3291.1kbits/s speed= 5.6x
Is this correct ? because it's so slow speed , I have AMD TR4 16 Core, I don't understand why it's so slow .. in the end I'll have FLAC file that I can move forward and backward ? Is there a way just to extract Dolby Atmos-TrueHD Audio and not to convert anything and just playback like it's normal file ?
thanks
* Is it possible to keep the ATMOS TRUE HD and to be able to playback with forward and backward ? and also so I would be able to edit it to cut the parts I don't wants ? because I would like to keep all the 3D detail the ATMOS is giving .. I don't think flac will keep that information right ?
EDIT : Ok I've managed to do it with Hybrid ... I needed to change some settings that I did not do before, now I have only the ATMOS TRUE HD AUDIO which is 3.5 GB , I can forward and backward .Last edited by x8009; 1st Jan 2019 at 18:19.
Convert Flac 24/96 5.1 to DTS ?
By webvan in forum AudioReplies: 3Last Post: 26th Nov 2018, 10:41 -
Best method to extract highest quality mp3 from YouTube?
By siratfus in forum AudioReplies: 14Last Post: 22nd Mar 2018, 17:26 -
MP3,WMA,DVD PCM but no WAV,OGG,FLAC,OPUS,AMR,etc.?
By TechLord in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Jan 2018, 11:17 -
Convert from dts 7.1 to flac 7.1
By sfatula in forum AudioReplies: 1Last Post: 31st Aug 2017, 18:40 -
Is FLAC file actually DTS-HD MA?
By PhilJW in forum AudioReplies: 7Last Post: 9th Dec 2016, 22:59
