    Nov 2005
    Hi, need a bit of help. Have got some HD .ts files from my Humax Foxsat.
    If I use Avidemux to convert to mkv they do play on my media player (Kodi/Pi) but not on my phone but on my media player the closing titles are nice and smooth like the original.
    Avidemux does the conversion very quickly so it is not re-encoding.
    I now have tried many video conversion software as listed on the top of this forum. But what ever I seem to do, the scrolling titles are jerky. But the do play on my media player & phone.
    The input Frame rate is 25FPS and so is the file after conversion, what am I doing wrong, what do I need to look out for when I set the various parameters for conversion.
    All of the software I have tried takes a while so it is being re-encoded.
    Regards Dave
    Aug 2013
    Central Germany
    Without a sample, even without a MediaInfo analysis, I can only guess that your original content might be interlaced. So you may have to do your recoding not frame based, but field based instead, to preserve the 50 fps of the fields in newly encoded frames and to avoid messing up your video due to scaling vertically across alternating lines.
    It is pretty common to e.g. downscale 1080i video to 720p, using a deinterlacer with bobber. The most elaborate one with probably the best possible results is QTGMC, but it requires founded knowledge of AviSynth scripting and a selection of several plugins with matching versions; converter applications of easier use may also provide TDeint or Yadif as quite good deinterlacers which can interpolate both fields to frames with double rate.
  3. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Have you tried MKVToolnix? Also post a MediaInfo report on one of the files.
    Nov 2005
    Hi, thanks for the reply media info as follows:-
    General
    Complete name : F:\TS Con\test.ts
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 870 MiB
    Duration : 29mn 1s
    Overall bit rate : 4 187 Kbps
    Video
    Menu ID : 6941 (0x1B1D)
    Format : AVC
    Format profile : High@L4
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Format settings, GOP : M=8, N=24
    Codec ID : 27
    Duration : 29mn 1s
    Bit rate : 3 561 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : MBAFF
    Scan type, store method : Interleaved fields
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.069
    Stream size : 739 MiB (85%)
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio #1
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : 6
    Duration : 29mn 1s
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Frame rate : 31.250 fps (1536 spf)
    Compression mode : Lossy
    Delay relative to video : -864ms
    Stream size : 39.9 MiB (5%)
    Language : English
    Audio #2
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Codec ID : 3
    Duration : 29mn 1s
    Bit rate : 256 Kbps
    Delay relative to video : -778ms
    Stream size : 53.2 MiB (6%)
    Language : nar
    Text
    Format : DVB Subtitle
    Codec ID : 6
    Duration : 28mn 56s
    Delay relative to video : 6s 94ms
    Language : English
    Other
    ID : 5403 (0x151B)-888
    Format : Teletext
    Language : English
    Menu
    Duration : 29mn 1s
    List : 5400 (0x1518)
  5. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Try putting it in a MKV container using MKVToolnix. You can drag and drop the file. You will also have the opportunity to untick any elements you don't need like subs etc and or unnecesary additional sound tracks. Should only take a few minutes to do. There may have been some transmissions errors so in this case run the TS file through TSDoctor first and see what that does. You can get a free fully functional trial version.
