Hi All,
apols if this has been answered elsewhere. I'm trying to merge a bunch of files (using Avidemux and/ or MP4Joiner) but some of them fail due to differing attributes.
So I'm wondering what's the definitive list of attributes that have to match on all/ both video in order to merge them.
I've read it includes...
Video:
Frame Width,
Frame Height,
Data rate,
Total bitrate,
Frame Rate,
Audio:
Bit rate,
Channels,
Audio sample rate.
I'm guessing that's not the full list. Can anyone point out others?
Thanks in advance.
Try a search using this thread title as the search string but use 'append' instead of 'merge'.
I would like to know this too for H.265 based video and how to get the values for those characteristics when there is no encoding setting information.
Frame Width -> important
Frame Height -> important
Data rate, -> not important
Total bitrate -> not important
Frame Rate -> important in case content is cfrusers currently on my ignore list: deadrats, Stears555, marcorocchini
How can you merge video files in Vidcutter?
By Stears555 in forum Video ConversionReplies: 3Last Post: 13th Apr 2021, 12:59 -
How to find single bit errors in otherwise identical video files?
By dgpretzel in forum EditingReplies: 6Last Post: 19th Feb 2018, 13:39 -
How merge X video files without opening video compression (it possible ? )
By yanshof in forum Newbie / General discussionsReplies: 9Last Post: 29th Dec 2017, 16:07 -
(Help Needed with ffmpeg) how do i batch merge audio files to video files
By wander799 in forum Newbie / General discussionsReplies: 5Last Post: 20th Nov 2016, 14:40 -
HD video in .mts format. How would i merge multiple files of this type?
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 2nd Mar 2015, 04:28
