Hello,
I use the 1080p camera and use the MJPG Streamer Version: svn rev: 3: 172 via Raspbery Pi 2
here everything works
On a remote server I do restream with fmpeg.
After transcoding, the picture moves quickly
CMD:
ffmpeg -re -i 'http://USER:PASSWORD@10.111.106.231:60068/?action=stream' -aspect 16:9 -pix_fmt yuv420p -c:v libx264 \
-profile:v baseline -b:v 1200k -filter:v "setpts=2.0*PTS" -an \
-vf drawtext="fontfile=/root/home_tv/Open_24_Display_St.ttf:text='%{localtime\:%T %d.%m.%Y}':fontcolor=black@1:box=1:boxcolor=yellow @1=10:y=10:fontsize=21" -x264opts keyint=75 \
-s 640x360 -map 0 -flags -global_header -f segment -segment_list /T9/home_tv_archive/live.m3u8 -segment_wrap 34560 -segment_time 5 \
-segment_format mpeg_ts -segment_list_type m3u8 -segment_list_flags +live -segment_list_size 34560 /T9/home_tv_archive/home%05d.ts
can you tell me where my mistake is?
I have an archive for 48 hours. So I'm guarded by thieves![]()
IMHO this is your problem (bold red):
You are forcing video to be played twice fast - remove this filter or at least change 2 to 1.Code:ffmpeg -re -i 'http://USER:PASSWORD@10.111.106.231:60068/?action=stream' -aspect 16:9 -pix_fmt yuv420p -c:v libx264 \ -profile:v baseline -b:v 1200k -filter:v "setpts=2.0*PTS" -an \ -vf drawtext="fontfile=/root/home_tv/Open_24_Display_St.ttf:text='%{localtime\:%T %d.%m.%Y}':fontcolor=black@1:box=1:boxcolor=yellow @1=10:y=10:fontsize=21" -x264opts keyint=75 \ -s 640x360 -map 0 -flags -global_header -f segment -segment_list /T9/home_tv_archive/live.m3u8 -segment_wrap 34560 -segment_time 5 \ -segment_format mpeg_ts -segment_list_type m3u8 -segment_list_flags +live -segment_list_size 34560 /T9/home_tv_archive/home%05d.ts -
I removed -filter: v "setpts=2.0*PTS" but the speed is still fast
I did a test with "setpts=1.0*PTS" but no resultLast edited by Veliko; 31st Dec 2018 at 11:47.
you can try to slow PTS (numbers lower than 1) but perhaps this is nature of source - i mean speed - i see -re option that imply native source speed processing thus everything looks correct. Record source and test offline.
8mm tape no picture except when fast forwarding
By boxcars20 in forum Capturing and VCRReplies: 16Last Post: 21st Jan 2020, 00:32 -
Poor picture quality during fast sequences
By Mike2112 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 6th Aug 2018, 04:38 -
Mitsubishi VCR - Can Only See Picture in Fast Forward or Rewind or Pause
By digicube in forum Capturing and VCRReplies: 2Last Post: 28th Jun 2017, 22:53 -
Animated flags, GIF, Cyber PowerDirector, Picture in picture
By SearchQuality in forum Video ConversionReplies: 9Last Post: 6th Apr 2017, 11:04 -
How to make Picture in Picture video??
By MEANGUNS in forum Newbie / General discussionsReplies: 6Last Post: 31st Dec 2014, 08:48
