Hello,
The case looks like that, using ffmpeg, I processed a lot of video recordings from a sport camera (Sony Action CAM AS200). On the original files there was no defect in the form of coalescence, picture jumping (especially on the details). I attach a short video that represents the problem.
Unfortunately, I do not have any original processed files. On which I used: file combination and image stabilization. I DO NOT use any compression in ffmpeg scripts. If it helps, I can give you which scripts I use.
I tried to fix the problem by ffmpeg using the command:
ffmpeg -i res_file.mp4 -c: v libx264 -crf 18 -vf fps = fps = 30 -c: a copy output.mp4
pause
Without result. I also tried to use the HandBrake program - including the option of fixed frames and thus converting the video. It also has not changed anything.
File properties with problem:
And a link to the cut out sample: https://youtu.be/wHCRL0guWNACode:General Complete name : O:\07.01.2018_PC.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom) File size : 8.14 GiB Duration : 1 h 8 min Overall bit rate mode : Variable Overall bit rate : 17.1 Mb/s Encoded date : UTC 2018-02-05 15:29:43 Tagged date : UTC 2018-02-05 15:29:43 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 1 h 8 min Source duration : 1 h 8 min Bit rate : 17.0 Mb/s Maximum bit rate : 47.6 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 29.970 FPS Minimum frame rate : 21.567 FPS Maximum frame rate : 29.970 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.274 Stream size : 8.08 GiB (99%) Source stream size : 8.08 GiB (99%) Writing library : x264 core 148 r2744 b97ae06 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=17000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Tagged date : UTC 2018-02-05 15:33:18 Codec configuration box : avcC Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Duration : 1 h 8 min Source duration : 1 h 8 min Bit rate mode : Variable Nominal bit rate : 128 kb/s Maximum bit rate : 137 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Source stream size : 62.3 MiB (1%) Default : Yes Alternate group : 1 Tagged date : UTC 2018-02-05 15:33:18
Is there anything I can do? I have concerns that many materials from my private archive from a few years may have such a defect![]()
Results 1 to 1 of 1
MP4 repair (AAC audio repair)
By holger123 in forum Newbie / General discussionsReplies: 16Last Post: 5th Jun 2020, 18:47 -
Video/Audio jumps out of sequence
By Mr_Flintstone in forum Video ConversionReplies: 13Last Post: 15th Mar 2016, 14:34 -
1st 12 min. of srt subtitles don't show up in VOB file film - how to repair
By Videosub in forum Video ConversionReplies: 6Last Post: 6th Aug 2015, 10:02 -
Awkward Jumps with Audio Normalization
By razlem in forum AudioReplies: 1Last Post: 21st Jul 2015, 00:59 -
MPG jumps ahead
By Stokesy in forum SVCD2DVD & VOB2MPGReplies: 27Last Post: 1st Jan 2014, 10:54
