Hi there guys,
I'm some-what new to the encoding process but I've been doing trail & error almost all year in trying different bitrates, encoders, aspect ratios, and filters. But I'm not getting the results I'm looking for as far as HD quality videos from the programs I've used.
My goals are to rip cartoons and movie DVDs that never got the digitally remastered treatment and give them a much better quality look almost to HD if possible. Plus trying to restore video game FMVs, mostly PlayStation 1 for the sake of preserving them for historical purposes.
The programs I've used have been Handbrake and VirtualDub. Now I've been studying up on other programs of properly encoding along with better deinteracing, denoise and color correcting. My research has lead me to a very known program AviSnyth yet I'm new to the script typing process.
Now I've tried to look at a few tutorials online of how to install it properly into my computer but still not working correctly.
Here are the specs of my computer
Right now I'm trying rip a CGI movie based on the G.I. Joe toy lineup, but getting poor results from between doing the MakeMKV to VirtualDub process.Code:Type - Desktop OS - Windows 10 (Home 64x) CPU - AMD A10-7800 Radeon R7, 12 Compute Cores 4C =8G 3.50GHz GCU - NVIDIA GeForce GTX 950 RAM - 12.0GB
Here's the mediainfo
This time I want to try using AviSnyth to see if it will give me a much better results with deinteracing, denoising, cropping, and resizing but need help trying to install the program correctly in order to do so. I'm willing to spend the time necessary in getting the best results.Code:CompleteName G.I. Joe - SpyTroops\G.I. Joe - SpyTroops.mkv Format/String : Matroska Format_Version : Version 2 FileSize/String : 2.33 GiB Duration/String : 46 min 16 s OverallBitRate_Mode/String : Constant OverallBitRate/String : 7 198 kb/s Encoded_Date : UTC 2018-12-29 17:49:29 Encoded_Application/String : MakeMKV v1.14.2 win(x64-release) Encoded_Library/String : libmakemkv v1.14.2 (1.3.5/1.4.7) win(x64-release) Video ID/String : 1 OriginalSourceMedium_ID/String : 224 (0xE0) Format/String : MPEG Video Format_Version : Version 2 Format_Profile : Main@Main Format_Settings : BVOP Format_Settings_BVOP/String : Yes Format_Settings_Matrix/String : Default Format_Settings_GOP : M=3, N=13 Format_Settings_PictureStructure : Frame CodecID : V_MPEG2 CodecID/Info : MPEG 1 or 2 Video Duration/String : 46 min 16 s BitRate_Mode/String : Constant BitRate/String : 7 000 kb/s Width/String : 720 pixels Height/String : 480 pixels DisplayAspectRatio/String : 4:3 FrameRate_Mode/String : Constant FrameRate/String : 29.970 (30000/1001) FPS Standard : NTSC ColorSpace : YUV ChromaSubsampling/String : 4:2:0 BitDepth/String : 8 bits ScanType/String : Interlaced ScanOrder/String : Top Field First Compression_Mode/String : Lossy Bits-(Pixel*Frame) : 0.676 TimeCode_FirstFrame : 00:01:29:00 TimeCode_Source : Group of pictures header Gop_OpenClosed/String : Open StreamSize/String : 2.26 GiB (97%) Language/String : English Default/String : No Forced/String : No colour_primaries : BT.601 NTSC transfer_characteristics : BT.601 matrix_coefficients : BT.601 Original source medium : DVD-Video Audio ID/String : 2 OriginalSourceMedium_ID/String : 189 (0xBD)128 (0x80) Format/String : AC-3 Format/Info : Audio Coding 3 Format_Commercial_IfAny : Dolby Digital CodecID : A_AC3 Duration/String : 46 min 16 s BitRate_Mode/String : Constant BitRate/String : 192 kb/s Channel(s)/String : 2 channels ChannelLayout : L R SamplingRate/String : 48.0 kHz FrameRate/String : 31.250 FPS (1536 SPF) BitDepth/String : 16 bits Compression_Mode/String : Lossy StreamSize/String : 63.6 MiB (3%) Title : Stereo Language/String : English ServiceKind/String : Complete Main Default/String : Yes Forced/String : No Original source medium : DVD-Video Menu 00:00:00.000 : en:Chapter 01 00:09:21.294 : en:Chapter 02 00:15:52.985 : en:Chapter 03 00:20:12.377 : en:Chapter 04 00:26:24.549 : en:Chapter 05 00:32:29.347 : en:Chapter 06 00:41:43.701 : en:Chapter 07
Results 1 to 15 of 15
I looked at a couple tutorial that was done in 2015 and another that was most recent. The problem I'm coming across for AviSynth or AviSynth+ is I can't figure out which one I'll need more in order to run AvsPMod or do I need both for it work. Plus don't know what commands to type in to start the encode process. I want to encode the video from d2v to MKV with the filters I need. Yes it says on the top it was converted already to MKV but I rendered another that's d2v from DGIndex.
Then you test out your script in VDub (or VDub2) to make sure it works and does what you want. Then you open that same script in an encoder that takes AviSynth scripts as input and can do the encoding for you. There are many. VDub2, RipBot264, Hybrid, are three that can do the job.
You could also post a short sample from the source for some more informed suggestions.
I believe AvsPMod is only for AviSynth (not the plus version).Last edited by manono; 30th Dec 2018 at 00:17.
Either will work. You only need one.
That depends on the source. For MPEG 2 in MKV I would start by demuxing the video with MkvExtractGUI, then use DgIndex to build an index file from that MPG file, then open index file in AviSynth with Mpeg2Source("whatever.d2v").
Note that AviSynth doesn't encode anything. It opens a file, filters it, then feeds uncompressed frames to another program -- an editor, encoder, or media player. -
Sorry for the late response, its been hectic since the start of the year.
Anyway, I've tried to follow the directions of this guy on YouTube on installing AviSynth+ but had a video tutorial for just AviSynth. The problems I'm facing is that avisynth.dll either in System32 or SysWOW64 isn't letting me use "SetMTMod" and the plugins seem to be for a 64 bit version of AviSynth its not +.
Here's how I arranged the files, maybe I'm doing it wrong but I don't know.
[Attachment 47883 - Click to enlarge]
[Attachment 47884 - Click to enlarge]
[Attachment 47885 - Click to enlarge]
[Attachment 47882 - Click to enlarge]
I just need some guidance on how to correctly install the program either AviSnyth or AviSynth+ on a 64 bit computer with all the settings including "SetMTMode" which isn't coming up for some reason using AvsPMod.
Update: I've since deleted all the files so I can start from scratch and do this installation right. -
SetMTMode is for the old avisynth 2.6 MT classic , not avisynth+ MT
Avisynth+ Mt uses prefetch(some number) at the end of the script. And SetFilterMTMode at the beginning (some filters require different modes)
Code:SetFilterMTMode("DEFAULT_MT_MODE", 2) . . . Prefetch(8)
http://avisynth.nl/index.php/AviSynth%2B#Setting_MT_modes -
Well that makes a lot of since, so AviSnyth+ uses SetFilter instead of SetMT. What about the plugins for AviSnyth+, which ones are 64 bit and where do I place them to?
SetFilterMTMode
x64 plugins
http://avisynth.nl/index.php/AviSynth%2B_x64_plugins
plugins64+ folder by default; but some people specify different directories
Or load them in the script in some other directory with LoadPlugin() to reduce clutter or to debug directory issues -
Manono, PDR, how the hell are you people? C'mere and give your uncle scooby a kiss!
Okay I'm finally getting some progress going with AviSynth+, but having a issue with doing QTGMC. Can I use QTGMC on +? I'm trying to denoise and sharpen a little bit of the video that's CGI or is there a better denoise tool for +?
[Attachment 47913 - Click to enlarge]
Also why isn't FFMpegSource2 working?
[Attachment 47914 - Click to enlarge]Last edited by SamFinisher; 26th Jan 2019 at 14:57.
QTGMC is a deinterlacer. You normally wouldn't use it for denoising and sharpening (some of it's side effects are denoising and sharpening). But on some low quality, problematic sources it can sometimes be useful outside of it's deinterlacing function
You need QTGMC.avsi and ffms2.avsi for those functions. If ever in doubt, search the avisynth.nl wiki. It will list various links and prerequisites . "avsi" are autoloading when placed in the plugins directory, or you can use Import("whatever.avsi") in the script
http://avisynth.nl/index.php/QTGMC
http://avisynth.nl/index.php/FFmpegSource -
The ffms2.avsi file shouldn't be required for FFVideoSource2. From The changelog:
- 2.22
- avisynth: Moved all source functions in ffms2.avsi into the actual plugin (Myrsloik)
You should also be able to use ffms2() instead of FFMpegSource2(), and if you're only opening video, maybe use FFVideoSource() instead, so ffms2 won't bother indexing the audio.
Aside from QTGMC and FFMpegSource2, the other functions you're using are native to Avisynth, so I assume plugins aren't being loaded.
Try loading them manually at the top of the script, from wherever they're located:
Import("D:\Some Location'\QTGMC.avsi")
LoadPlugin("D:\Some Location'\ffms2.dll")
I'm still using XP so I can only ask.... does your screenshot showing Avisynth+ installed to the Program Files (x86) folder with a 64 bit plugins folder make sense?
To me that implies you're running a 32 bit version of Avisynth and trying to load 64 bit plugins, but I could be totally wrong.
I use QTGMC for denoising quite a bit. It's not without some side effects (being a de-interlacer) but as a general rule I find it better than most de-noising scripts. If you're not de-interlacing though (your source is progressive) you should use it in progressive mode.
QTGMC(InputType=1, EzDenoise=1.5) #denoise values between 1 and 2 are usually enough.
or for a bit of a speedup
QTGMC(InputType=1, Preset="medium", EzDenoise=1.5)
https://forum.doom9.org/showthread.php?p=1855055#post1855055
Joining, deinterlacing, and encoding MOD source files to progressive h264
By nicholasserra in forum Video ConversionReplies: 45Last Post: 5th Dec 2017, 11:41 -
Sharpening after Denoising
By Valmont in forum Newbie / General discussionsReplies: 3Last Post: 27th Dec 2016, 12:17 -
AviSynth: Weird deinterlacing issue causing 'big' interlace lines to appear
By SMGJohn in forum RestorationReplies: 15Last Post: 9th Jul 2016, 08:42 -
Denoising, Deinterlacing, and Crop
By Anon45 in forum EditingReplies: 4Last Post: 19th Mar 2016, 13:13 -
Idea for perfect denoising
By Mephesto in forum RestorationReplies: 6Last Post: 24th Jan 2015, 07:18
