Is there a media player that can force the video frames to become from 30 fps to 23 fps or 25?
P.s: am on mac
With thanks
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Remux with MKVToolNix GUI, but you need to reencode Audio, but this way the video will be played faster or slower than in original.
What is your intention of doing that? -
You mean, there's an annoying stutter (caused by duplicated frames) when the video plays ?
On a Windows system that could be done with a simple Avisynth script, loaded with AVFS, which turns the script into a virtual AVI file, then any player can play the script as if it was an actual file converted with an altered framerate. I don't know if there's anything equivalent for Apple computers. You could always install a virtual Windows just for that purpose...
Womble MPEG Video Wizard changing aspect ratio and skipping frames.
By magnu in forum EditingReplies: 8Last Post: 31st Oct 2018, 03:15 -
Number of frames change after converting
By vivabarca in forum Video ConversionReplies: 1Last Post: 12th Oct 2016, 08:47 -
Removing frames without converting?
By videohalp in forum EditingReplies: 8Last Post: 3rd Feb 2015, 08:27 -
Having trouble converting and burning a DVD player video
By nite_hawk in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2014, 15:27 -
changing region on Philips PD9012/37 portable dvd player
By joalina87 in forum Newbie / General discussionsReplies: 7Last Post: 31st Dec 2013, 08:02
