I prefer my srt sub's maximum line length to be 35 characters. With lines longer than 70, editors I've used can create a single line break but not more. I mainly use Subtitle Edit and sometimes Subtitle Workshop and have a checked a couple of others like Aegisub and they can't do it.
Anyone know of a program with a higher limit of the top of their head so I don't have to check them all one by one? Splitting lines isn't an option.
EDIT: AHD Subtitles Maker does it but poorly because it doesn't balance line lengths so not looking for that sorta thing.
Results 1 to 20 of 20
How exactly are you helping by telling me to use programs I said I used already? Please explain. I don't know. Perhaps you're handicapped and are serious?
I haven't seen a subtitling app that automatically breaks across three lines, probably because professional standards recommend against it.
Yes, I read that about standards not recommending this when I started to look into it but most streaming services seem to ignore it. I just reads easier for me. As long as there aren't a lot of closeups of faces, which would look bad to me, I prefer it and have started to manually do a few like that.
In Subtitle Edit go to Options/Settings and on the first tab you can change the maximum number of lines from 2 to 3. You may also want to change the maximum line length to match your preferences as well.
I already stated that I use Subtitle Edit so I already know all that. Doesn't help the situation because as I already said, it can only create a single line break.
If your media player accepts .ass or .ssa format subs then you could specify the location on the screen of the lines if you used either formats instead of srt. https://www.matroska.org/technical/specs/subtitles/ssa.html
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
You know, your attitude strikes me as just a bit tart for someone who's asking for free help.
Some people enjoy being unhappy with life and unappreciative of free help when offered. I'm out of this thread I'm sure the OP will never be satisfied nor willing to experiment. Very sad case.
OP No such program exists that does your task automatically?
Worst case scenario is
1. Open you file in subtitle edit/ subtitle workshop
2. Do the split line after character 35
3. Sort the subtitles by line length
3. save the file as SSA
4. get a text editor (use notepad++) it's free.. Enable the line ruler5. Go to the lengthier lines (that may be simpler since these will be fewer)
6. insert\N where appropriate. (\N is the line break in SSA)
7. Open subtitle edit/ subtitle workshop
3. Sort the subtitles by time
8. Save file in srt
Now Go get to workLast edited by teodz1984; 31st Dec 2018 at 06:43.
In Subtitle Workshop
Step 1: Settings --> General --> Advanced --> and setup Smart Line, Devide lines, Maximum line length to 35; also check Smart line adjust automatically;
Step 2: Edit --> Texts --> Set maximum line length...
And that's it. -
Closed captions for the hearing impaired (NTSC, ATSC) only support a line length of 32 characters. I can suggest using Subtitle Edit to convert your subtitle to a closed caption format (Sonic Scenarist *.scc comes to mind) and then convert the closed caption file to your preferred subtitle format. Quick-and-dirty, no messing with settings or anything.
Program to remove streaks, lines, spots from VHS?
By Master Tape in forum RestorationReplies: 10Last Post: 10th May 2020, 16:42 -
Aegisub won't highlight lines that are too long
By 1v4n0 in forum SubtitleReplies: 3Last Post: 13th Jan 2018, 07:00 -
To long lines in subtitle
By suadnovic in forum SubtitleReplies: 2Last Post: 18th Jun 2017, 14:09 -
How can I remove these lines?
By killerteengohan in forum RestorationReplies: 15Last Post: 16th Mar 2015, 04:19 -
DVDR with Lines on Top and Lines on Bottom?
By Disco Makberto in forum MediaReplies: 13Last Post: 14th Feb 2015, 03:34
