Obviously, I'm not satisfied with the original color and quality of the video which is why I use Sony Vegas to change the video's properties. Isn't that the whole point of using a video editor to begin with? Also, if I just render the video without adding any fx and changes, it would still come out saturated and off-colored anyways. In other words, the rendered video will still look different from what I see in the Preview Window.
Results 31 to 34 of 34
First of all we are trying to figure it out what is wrong with your settings, over the internet, that is causing a color shift from what you see in the preview and what you get in the output. It could be anything, your GPU, your video player, we don't know. In Premiere and Davinci we can select what the preview will display, I never use Vegas in my life, I never work with PAL, you don't know what PAL is all about, we don't know the sources you are using, you didn't use the videos we provided to see how much off your color and levels are.
You know that not even paid support works on Sunday.
Sorry I can't help you any further, I hope someone else could help you out with your issues.
Good night. -
Hey, guess what! I finally found the solution to my long-enduring problem! Turns out I was right all along. It was the settings in Potplayer that were responsible for the massive frame drops that I was experiencing when I switched video renderers. I was tinkering and experimenting so much with the settings in Potplayer that I wasn't aware this lead to all sorts of problems with my video playback. So I restored the default settings by uninstalling and then reinstalling Potplayer. I then went to preference and switched the Video Renderer from "Auto (Recommended)" to "Video Renderer". And now I have the video quality that I always wanted and the video plays smoothly with no frame drops whatsoever!
Potplayer + MadVR, GPU usage is halved when resized or fullscreen?
By Rumba47 in forum Software PlayingReplies: 0Last Post: 10th Jun 2018, 14:58 -
Potplayer fullscreen mode without resizing or scaling
By gregory003 in forum Software PlayingReplies: 2Last Post: 18th Mar 2018, 00:05 -
is it just me or the video lags after the encoding?
By zanzar in forum Newbie / General discussionsReplies: 18Last Post: 2nd Apr 2016, 17:17 -
How to mplayer video fullscreen and keep original video resolution?
By leandro in forum Software PlayingReplies: 18Last Post: 25th Dec 2014, 10:37 -
need to edit audio in my video , can i avoid to render/recode the all video
By rama in forum EditingReplies: 15Last Post: 8th Nov 2014, 02:42
